 Post subject: needed firmwares
PostPosted: September 14th, 2010, 7:27
hi
i need some firmwares for
wd3200aajs-00l7a0
s/n: wmav2p410371
date: 28 jan 2010
dcm: harnhtjce
ma
wd1600avjs-63wna0
s/n: wcas2d519554
date: 27 feb 2009
dcm: dhrnntjahn
th
wd1600aabs-00pra0
s/n: wmap9f156121
date: 31 mar 2008
dcm: hannntjcg
ma
wd3200avjs-63b6a
s/n: wca1d403106
date: 26 aug 2009
dcm: hbnnht2chn
th
wd10eads-00l5b1
s/n: wcau4d993285
date: 13 nov 2009
dcm: hannht2mab
th
please help me with that request
bye
 Post subject: Re: needed firmwares
PostPosted: September 14th, 2010, 10:57
chk the files box here 1st
http://files.hddguru.com/
PostPosted: September 14th, 2010, 11:09
casper_egy_2006 wrote:
hi
wd3200aajs-00l7a0
s/n: wmav2p410371
date: 28 jan 2010
dcm: harnhtjce
ma
wd1600avjs-63wna0
s/n: wcas2d519554
date: 27 feb 2009
dcm: dhrnntjahn
th
wd1600aabs-00pra0
s/n: wmap9f156121
date: 31 mar 2008
dcm: hannntjcg
ma
wd3200avjs-63b6a
s/n: wca1d403106
date: 26 aug 2009
dcm: hbnnht2chn
th
wd10eads-00l5b1
s/n: wcau4d993285
date: 13 nov 2009
dcm: hannht2mab
th
bye
Do you need specific FW revisions? It is pretty dangerous attempting SA repairs with non-matching firmware revisions...
PostPosted: September 14th, 2010, 14:08
i can't find firmwares
please help me
PostPosted: September 15th, 2010, 3:51
Then maybe you should not proceed further...
PostPosted: September 15th, 2010, 5:26
not proceed further in what?
please help me in my request
PostPosted: September 15th, 2010, 5:31
Good disk operation is dependant on good firmware, which needs to be compatible with the rest of the disk. If you plan on replacing or repairing SA information without matching firmware revisions you can cause irrepairable damage.
What do you need firmware for? Maybe if you clarify a little we can be of more help to you.
PostPosted: September 15th, 2010, 6:38
i use pc3000 and i need the firmwares because i replaced pcbs
PostPosted: September 15th, 2010, 6:53
this makes no sense.
Replacing PCB will make ROM incompatible. If there a physical ROM chip you need to change it, but most likely is embedded to MCU. In this case you need restore ROM from copies in SA.
Chances of finding donor ROM that is compartible is very unlikely.
PostPosted: September 15th, 2010, 7:25
if u have firmwares send to me
PostPosted: September 15th, 2010, 8:40
hi
wd3200aajs-00l7a0
s/n: wmav2p410371
date: 28 jan 2010
dcm: harnhtjce
ma
wd1600avjs-63wna0
s/n: wcas2d519554
date: 27 feb 2009
dcm: dhrnntjahn
th
wd1600aabs-00pra0
s/n: wmap9f156121
date: 31 mar 2008
dcm: hannntjcg
ma
wd3200avjs-63b6a
s/n: wca1d403106
date: 26 aug 2009
dcm: hbnnht2chn
th
wd10eads-00l5b1
s/n: wcau4d993285
date: 13 nov 2009
dcm: hannht2mab
th
bye
PM ur email :?
PostPosted: September 15th, 2010, 8:46
casper_egy_2006@yahoo.com
thanks alot
PostPosted: September 16th, 2010, 13:57
anyone help me in my request please
