Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Samung HM250JI - not detected after PCB swap
PostPosted: September 16th, 2010, 5:23
Ok Janos, thank you but I'm a problem. The patient original Marvell Chip is probably burnt. I see it with my eyes.
So, if I can't use the original Marvell chip, all the datas are lost, not ?
Samsung Marvell chip is the same as Hitachi NVRAM with unique informations for each HDD. Is it exactly ?
PostPosted: September 17th, 2010, 2:46
If the original Marvell Chip is burnt nobody can help you. Forget about this HDD.
PostPosted: September 17th, 2010, 4:12
This is not true, i can help, if the hdd comes in to my lab....
PostPosted: September 18th, 2010, 7:19
Agreed.
Perfectly possible to recover, but not DIY.
PostPosted: September 22nd, 2010, 4:41
Has anyboy have exactly the following marvell rom file ?
88i6726S-TFJ2
YPM17026
0832 B0P
TW
PostPosted: September 22nd, 2010, 5:17
Once for all :
Yan, the marking on the chip have nothing to do with code.
I can put the code I want on the chip as I usually do.
PostPosted: September 22nd, 2010, 8:09
Yes, I understand but how to find the code of the original patient rom.
The patient rom is burnt.
PostPosted: September 22nd, 2010, 9:13
From the other half of the apple ;)
PostPosted: September 22nd, 2010, 9:23
Taking a stab at it but I suspect you have to rebuild it manually with the right tools. It's not something you can just download.
PostPosted: September 22nd, 2010, 9:30
Can't be rebuilt and there are no COMMERCIAL tools yet. Need something else more.
PostPosted: September 22nd, 2010, 10:23
we can make it with non-original PCB work or do with some way for access data area. the special way is use Samsung factory software for re-write FW(with this way you will take around 1 Min for make it work with Non-original PCB) :)
data recovery service[/b]
PostPosted: September 22nd, 2010, 11:09
Wrong, because in their case heads were changed and there's something else. If you do so, writing - if you don't get an error immediately- you'll fuck the drive for sure. They can't access the 'sa' right now and rom is k.o. And you don't know config and sub-variants so you can't write a generic code . So your idea won't work. My only problem is that I can't handle their case and they are not here...
PostPosted: September 22nd, 2010, 14:17
all words in one: This case is recoverable in any decent lab. :)
PostPosted: September 22nd, 2010, 23:30
sorry. i mentioned operation with chage PCB only. may be your opinion is right. i have been done with HM160HI similar case. of course their no the same condition. as your mention if writing is done. drive is over? i think may be no. there should be have others ways for access :wink: please correct if i am wrong.
PostPosted: October 15th, 2010, 3:48
Hello.
News informations about this case.
The terminal log is not exactly the same this one.
On the patient hdd, there are the new hsa donor and new pcb donor.
What do you think about it ?
 1.5G Limited
SPW 1.5G Link Ok!
IS=+00003
SO
H: +00000
Ld
SK C: 00001699
ENG>SRV>
SvoTbl Loaded
AEST
C: 0000032A H: +00003
SK C: 000043E3
BD
 1.5G Limited
SPW 1.5G Link Ok!
IS=+00004
SO
H: +00000
Ld
SK C: 00001557
ENG>SRV>
SvoTbl Loaded
AEST
SK C: 00004401
BD
 1.5G Limited
SPW 1.5G Link Ok!
IS=+00003
SO
H: +00000
Ld
SK C: 00001247
It seems that the hdd search his SA zone, not ?
I let run the hdd a few minutes and the "SK C: xxxxxx" change.
Do you think that in a few minute, the hdd will find the zone and initialize ?
Thank you in advance for your answer.
Users browsing this forum: Google [Bot] and 198 guests
