Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: seagate ST380215AS
PostPosted: September 17th, 2010, 19:02
Seagate st380215as firmware 3.aad
on tmos
Stuff Was Unreadable
and i cannot run some commands
Command Inactive - No VALID Cert Code Detected
how can i fix Stuff Was Unreadable?
 Post subject: Re: seagate ST380215AS
PostPosted: September 17th, 2010, 23:35
1024k x 16 DRAM
NHAWK - 1_Disk S-42 03-27-07_11:48
Buzz HM SFI
(P)SATA Reset
Stuff Was Unreadable3
PostPosted: September 18th, 2010, 7:06
With the right tools and knowledge, that's how.
Not DIY
PostPosted: September 18th, 2010, 7:25
What tools do you have?
ACELab partner
PostPosted: September 18th, 2010, 8:10
only software (putty,HyperTerminal,st_mem_win_free) and rs232 ttl (Seagate RS-232 adapter)
PostPosted: September 18th, 2010, 8:56
Lack of resources....
PostPosted: September 18th, 2010, 10:57
Not enough...
ACELab partner
PostPosted: September 18th, 2010, 11:45
what do i need except stuff like pc3000 (i have acess to eeprom programmer, smd rework station)
PostPosted: September 18th, 2010, 12:36
Sorry, but you can't perform heart surgery with a butter knife and some bulldog clips :roll:
I respectfully suggest to seek pro advice on this one if the data is worth anything to you.
PostPosted: September 18th, 2010, 13:46
I'm not interested in the data i need the hard drive.
the hard drive was accidentally locked with password
PostPosted: September 18th, 2010, 14:15
is cheapper for you to buy a new one.
ZeBong
" Россия еще раз"
PostPosted: September 18th, 2010, 14:26
Bullshit. If the drive was only locked, you wouldn't have CERT and STUFF problems.
Either : 1) you or someone else have tinkered with commands and internet stuff and now the drive is screwed , or 2) the problem was elsewhere : the drive APPEARED locked in the first instance due to the severe corruption, then it haven't worked anymore after power cycle.
The 1st scenario seems more probable.
It is possible to "rebuild the drive from scratch" in order to reuse it, this is sure (assuming surface and heads are OK) but I can't tell you how. Maybe in the Seagate forums, or on other forums, who knows ....
PostPosted: September 18th, 2010, 14:29
Bollocks
PostPosted: September 19th, 2010, 4:38
the hard drive was locked i tried to unlock it wit tmos (followed the information on internet) and now this problem stuff and cert
PostPosted: September 22nd, 2010, 8:05
the drive is still locked after rewrite of stuff
how can i unlock master password ?
PostPosted: September 23rd, 2010, 0:17
WTF are you saying, man? I can't figure out exactly what it is your saying much less what it is you are wanting to do.
PostPosted: September 23rd, 2010, 0:30
i cannot edit that post anymore.. there was a copy paste problem ...
i keep receiving that on terminal form hdd
Preamp Sent Greater than Max Allowed Bias (FF-15)
$SFI
AMR
$SFI
AMR
$SFI
AMR
is this a problem with head amplifier?
PostPosted: September 23rd, 2010, 1:41
The stuff is not from an identical hdd i think this is the causing this
Does the hard drive have a backup for stuff data?
PostPosted: September 23rd, 2010, 2:40
another problem
Reset
1024k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
(H)SATA Reset
AT Er 00 Nwt Er fe RdWr 289a14.00.0219
ATA St 80 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 017200f7 b6 017200f7.1.58b 0000 005f 0000 0000 c67178
DiskAccess ReadSector EC=fe at 289a14.00.0219
CE Log ErrCode=fe LBA=f91d0000 Type=5 Add To Pending f91d0000
AT Er 00 Nwt Er fe RdWr 289a14.00.021a
Niwot: 027f00f7 b6 027f00f7.1.58b 0000 005f 0000 0000 c67178
DiskAccess ReadSector EC=fe at 289a14.00.021a
CE Log ErrCode=fe LBA=f91d0001 Type=5 Add To Pending f91d0001
AT Er 00 Nwt Er fe RdWr 289a14.00.021b
DiskAccess ReadSector EC=fe at 289a14.00.021b
CE Log ErrCode=fe LBA=f91d0002 Type=5 Add To Pending f91d0002
AT Er 00 Nwt Er fe RdWr 289a14.00.021c
DiskAccess ReadSector EC=fe at 289a14.00.021c
etc
how can i fix this?
PostPosted: September 27th, 2010, 14:59
http://newsgroups.derkeiler.com/Archive ... 00009.html
Seagate Terminal might be the right tool, if you an find an appropriate firmware cert and overlay in the downloads section or elsewhere, and it appears to have the factory certification and other tests available, but I haven't used it much, and its all in Russian. Use Google translate for the rich text doc file. The first time you copy everything from the file into Google and hit translate, it will punk out and only translate the first few lines. Go back and delete those few lines and then hit translate again, and it will work and translate all of it.
It is unfortunate we have no American Spetsnazt, or there would be an English version.
Spesibo, to all Russian droog Spetsnazt...
http://www.youtube.com/user/TerraformingMaster
Users browsing this forum: Google [Bot] and 197 guests
