 Post subject: WD5000AAKS-00TMA0 PCB Error
PostPosted: September 10th, 2010, 13:01
WD5000AAKS-00TMA0
PCB is 2061-701477-800 AB ( 88i6745-TFJ1 ) adaptive data in rom
Status:Drive dead
Seems no communication at all with the pcb in normal ore PSV mode at all using wd doctor.
Changed SMOOTH with no result
No signs og burned chips,
Any hints om what else to check on these boards ?
Im afraid this is a bad marvel any hints please
Digisupport
Digitalsupport Data Recovery
https://digitalsupport.dk
 Post subject: Re: WD5000AAKS-00TMA0 PCB Error
PostPosted: September 10th, 2010, 13:41
I have some of these drives here and the WD Doctors has some major issues on them trying to start them in this tool. You might want to try an external power source to start this tool with. When you try to use your PS on this drive it is not getting enough power to this tool to start this drive with it. You will get on power on when you hit the power button, bsy, then no hdd. This can also be a problem from the tool and not only your PCB board. This tool has to be played around with in order to read these drives from it. I had one that came ready showed ready and when trying to load from HDD was in Ready status but the program said no HDD on this one. Use the smallest IDE cable possible on this one and go out and buy some new power cable to use in your output on this tool. Then get an external power supply used for powering up your HDD like the one that comes with the USB multiple connector that you can attach a 3.5, 2.5 SATA or IDE to it. This one works very well in powering up this tool. Test this before doing anymore to this PCB or opening up this drive.
Iorana Haraharaini
PostPosted: September 10th, 2010, 14:13
Thanks for your sugestions Ann, i am on external power as i experianced trouble to get another WD5000AAKS running. But this one seem like tere is no communication at all, no change of state at all.
Ill have to look closer om power supply for the marvel chip..
Is recovery posible without adaptive data from marvel chip om these series ?
Digisupport
PostPosted: September 10th, 2010, 14:55
Check out in SD forum on how to do this one with Mods from your HDD on this.
Iorana Haraharaini
PostPosted: September 10th, 2010, 16:00
If the MCU is dead, the last resort is to get out the SA in some way from the drive (hope the headstack is not killed too :?) and then rebuild ROM on a fresh PCB. I can't see anything else.
PostPosted: September 14th, 2010, 1:38
I vote for dead MCU or bad preamp.
PostPosted: September 19th, 2010, 5:22
Thansk for all your input, MCU is dead..
Any hints on how to rebuild ROM on a fresh PCB..
Digisupport..
PostPosted: September 19th, 2010, 5:32
More than a hint : dig in your pockets or outsource the case.
I think it's beyond the capabilities of WD doctor (but I can be wrong), so you need "other" tools. AND, beside MCU dead, I think there can likely be something else.
PostPosted: September 19th, 2010, 6:23
Personally I wouldn't trust WD Doctor on this one. For one it can't even see the head map properly on these drives!
You have PM
PostPosted: September 19th, 2010, 6:56
Checked the TVS ? :)
PostPosted: September 19th, 2010, 7:00
One would "assume" he's tried this, having gone to the extents of changing the Smooth chip :roll:
PostPosted: September 19th, 2010, 12:46
assumption is the mother of all F... up's 8oP
PostPosted: September 20th, 2010, 2:58
So true!! :lol:
PostPosted: September 20th, 2010, 18:46
Thanks for all your inputs.. and yes i checked tvs.
original pcb is working fine on another drive..
This is not a customer case if it was, i would have sent it to someone with more experience, thanks for your offer pcimage, ill get back to you next time i outscource a job.
Im still learning..
Digisupport..
PostPosted: September 21st, 2010, 10:52
original pcb is working fine on another drive..???
Status:Drive dead
PostPosted: September 21st, 2010, 13:31
Status:Drive dead
original pcb is working fine in another drive with that drives MCU..
So i think status is dead MCU
Digisupport
PostPosted: September 21st, 2010, 18:37
ah now I get it :O)
Users browsing this forum: Bing [Bot] and 61 guests
