 Post subject: WD Caviar problem: WD1000BB-75CHE0
PostPosted: September 21st, 2010, 8:01
I have a WD1000BB-75CHE0 that makes a clicking sound and then slows down and stops.
MHDD gives the following results:
WDC WD1000BB LBA:0
SN: some rubbish FW: 22.04A CACHE: 8192 Kb
SUPPORTS: MS16 SIZE: 0 Mb
Does not support LBA mode.
MHDD will not work with this device
Has anybody some advice for me?
Edsel
 Post subject: Re: WD Caviar problem: WD1000BB-75CHE0
PostPosted: September 21st, 2010, 8:04
Most likely heads are damaged and the ID you see is partial ID from ROM
Professional diagnosis is required for a more accurate diagnostic...
PostPosted: September 21st, 2010, 8:09
Agree with HDDGuy Heads might Damage do u have Professional Tools ? if not send to any Pro.DR company DIY will not work on it .
PostPosted: September 21st, 2010, 8:47
Yes, I was afraid for that but the topic of BGman gave me some hope:
In the case of WD drives I have found a relatively easy way to identify drives with broken heads. Just put the drive in safe mode and use the ID command (MHDD). If the drive reports the same model as on the label the heads are OK, if not - there is a head broken.
For example WD400EB could identify itself as WD1000BB (no good heads) or WD200EB (1 good head).
You find it on
clicking-noise-drives-bad-head-t7820.html?hilit=wd1000bb
Edsel
PostPosted: September 21st, 2010, 16:33
On those drives it's very common with bad Pcb's.
As you have access to pc3000, put the pcb in kernel, read out the rom, find a good pcb with the same number 2060-001102-xxx and replace the rom (or desolder the u2 chip, and replace on donor).
I have this in stock if you need donor for heads:
W0035, 1000BB, 75CHE0, 13-okt-01, HSEHBT2CH, 2060-001102-002
Regards/ Bosse
http://www.rescue-it.se
Users browsing this forum: Google [Bot] and 146 guests
