 Post subject: Can't recover a memory card after it had been formated
PostPosted: September 18th, 2010, 23:49
Hi all,
I got today to my lab a memory card after it had been formated in Canon carmera.
This is the card:
http://img705.imageshack.us/img705/6083/dsc04348n.jpg
The label drive that the carmere created for it is CANON_DC. The file sistem is FAT32.
I tried to run few known softwares for that recovery before taking seriously steps like unsoldering the chip out and connect it to a nand reader.
I don't understand why after a simple format from th carmera, non of the softwares can recover the data from it.
Any ideas?
Any good softwares?
Many Thanks!
 Post subject: Re: Can't recover a memory card after it had been formated
PostPosted: September 19th, 2010, 5:23
It depends Canon EOS cameras quick format the flash. And maybe the user used RAW mode for photo's
PostPosted: September 19th, 2010, 6:58
Check it out with Winhex.
Do you see data there, or just "00"?
If there is data, try "photorec" on it. That sees Canon raw (CR2) files as well as regular JPG
PostPosted: September 19th, 2010, 16:51
Hi pcimage,
Thank you for the tip.
I got the software winhex but unfortunately just the 23 first rows are with data and all the rest are "00"..
(Or I didn't use winhex right).
Is there any chance of recovery data from that card after a simple format?
(Or it was an innocent format after all?!)
Many Thanks!
PostPosted: September 20th, 2010, 3:38
Some camera's dont just format but erase the card also.
I think this is one of them.
Forget the data, its gone :(
dobre
Murphy was an optimist
PostPosted: September 20th, 2010, 18:29
dobre
Even with Nand reader the recovery is impossible?
Or I didn't get the purpose of Nand reader?
PostPosted: September 21st, 2010, 2:57
Nand reader reads directly from the memorychip, but if the card is erased, the memorychip is erased; the result is the same.
Data is gone.
PostPosted: September 21st, 2010, 18:40
Emm.. Bad news to me and to my customer.
Is there any Black Magic for that? :?
PostPosted: September 22nd, 2010, 2:43
Sorry, no
PostPosted: September 22nd, 2010, 2:53
Nope, once the beer has been drunk, it's gone!
PostPosted: September 22nd, 2010, 5:20
could you tell me here, which Appz u tried with ur memory?
and status result of each ?
PostPosted: September 22nd, 2010, 14:46
If the format method use internal erase, there's no chance. The mechanism require a command and the chips / card autonomously - in seconds! - perform a block erase and zerofill itself. Then the Fs and header is created. If the card is seen 'zeroed' , that's probably what happened.
Users browsing this forum: No registered users and 88 guests
