 Post subject: seagate hdd erase when locked with password???
PostPosted: September 22nd, 2010, 10:24
i want to erase the locked hdd from tmos to erase the password the data is not important
 Post subject: Re: seagate hdd erase when locked with password???
PostPosted: September 22nd, 2010, 10:27
nice try- but you cannot write or read data on locked hard drive.
You need to get the master password somehow or crack it using equipment, software. If you in the UK i can do it cheap for you.
Good luck
Free Solutions
PostPosted: September 22nd, 2010, 11:12
still the same drive? I think the pw lock is the latest problem... if it is really locked.
PostPosted: September 22nd, 2010, 11:36
The same "stuff was unreadable" drive?
PostPosted: September 22nd, 2010, 11:43
Oh.. its not ATA lock. Well- i could still "repair" the drive if you want. but is it worth it?
Free Solutions
PostPosted: September 22nd, 2010, 13:03
yes is the same drive with the stuff unreadable i found another drive to read the stuff (st380815as 8mb cache instead of 2mb st380215as) now the stuff is ok but is still locked
PostPosted: September 22nd, 2010, 13:43
Mister, you have a confused idea about STUFF...
PostPosted: September 22nd, 2010, 14:54
connected the hdd ctrl+z and then ctrl+u to print the stuff on working hdd then on the hdd with the stuff problem....
T>
T>F
SetStuff->ASCIXXQQQQ
XX-ADDRESS QQQQ-DATA IN ASCII (HEX DATA) from the working hdd ...
PostPosted: September 22nd, 2010, 15:09
You said :
"i found another drive to read the stuff (st380815as 8mb cache instead of 2mb st380215as) now the stuff is ok but is still locked"
And you expect it will work beside the "ATA LOCK" problem ? At least you must borrow the STUFF from identical drive
PostPosted: September 22nd, 2010, 15:37
Where can I get this STUFF you guys keep talking about? 8)
PostPosted: September 22nd, 2010, 15:42
Eeeeehhh.... must ask Don Vito / Don Pedro / Don Perignon.... :D ah no, it was "DOM" :lol:
(Also : never read G. Verga ? "la roba" = "the stuff" - ok, it's absolutely difficult for non-Italians)
PostPosted: September 22nd, 2010, 22:54
it was the standard password ........ hope the drive is not broken...
how can i remove the password feature permanently ?? ...
PostPosted: October 1st, 2010, 4:17
if u have access to firmware edit vendor track 6th sector write 00 00 in first 2 byte and save it back , your password is removed.
Users browsing this forum: Google [Bot] and 239 guests
