 Post subject: Help with HDD in bios (Seagate)
PostPosted: September 23rd, 2010, 21:12
Hey all I am having some issues with a Hard Drive I am running Windows XP SP3.................................................................................
My PC wont boot when my secondary drive is physically plugged in to the mobo. For the record the drive has no OS installed on it and it is a NTSF It just has data on it.
I am running XP SP3 and Im sure I have all the SATA cables going to the right place
When I boot with both HDD connected It just hangs at the Windows loading screen without any bars actually progressing.
I believe the problem is Windows is trying to boot from the second HDD I just don't know how to fix it.
Also last night I took everything out and apart to clean some dust after it was all said and done. I rebooted about 3 times just to make sure. There was no problems. The PC was off all day and when I tried to boot tonight ^^^^ happened.
Some other things I tried.......
I dissconected all other devices such as DVD-rom and external HDD to eliminate problems.
When i go into bios with only primary(WD) and the secondary(Seagate) connected to the mobo, the primary is the only HD detected.
I tried having only the second(Seagate) HD connected to the primary slot on the motherboard and I still get no detection out of the bios?
I am sure the HD (Seagate) is getting power because I can hear it and I eliminated that problem by trying different Power Cables
Has the Seagate seen its days?
 Post subject: Re: Help with HDD in bios (Seagate)
PostPosted: September 23rd, 2010, 22:37
What is the Drive's Spec? Full Make & Model and etc...
It sounds like the drive is physically damaged
PostPosted: September 23rd, 2010, 23:05
Seagate
Barracuda 7200.11
500 Gbytes
model#
ST3500320AS
Let me know if you need to know anything else.
PostPosted: September 24th, 2010, 2:40
What's the firmware version of the Seagate?
PostPosted: September 24th, 2010, 10:09
100$ on SD15 =)
PostPosted: September 24th, 2010, 11:09
SD1A is it ?
RAID/Server Recovery
PostPosted: September 24th, 2010, 11:18
Chinopk and SD1A vs Alexii and SD15 for prize of $100 8)
PostPosted: September 24th, 2010, 12:53
How would I be able to check the firmware version without being able to boot the pc with it connected?
I have never updated the firmware since purchase so maybe it has a default firmware version?
PostPosted: September 24th, 2010, 12:55
It's listed on the label
PostPosted: September 24th, 2010, 13:04
Hey thanks yea its SD15
PostPosted: September 24th, 2010, 13:08
I would check this out: tutorial-resolve-lba-seagate-7200-bios-don-recognize-t11040.html
Make sure to pay full attention to all of the warnings though.
Last edited by XanderSholtz on September 24th, 2010, 13:20, edited 1 time in total.
PostPosted: September 24th, 2010, 13:16
edit
Thanks,
GB
PostPosted: September 24th, 2010, 13:28
Now i am at my desk , and can say what i wanted to say when i was at my bosses desk.
I win =)
Cheers.
PostPosted: September 26th, 2010, 7:26
gr8 u win 100$ is urs
PostPosted: September 29th, 2010, 15:09
give nao? =)
PS OP how did it go ?
Users browsing this forum: No registered users and 233 guests
