 Post subject: Maxtor Diamond Max 8 Plus PCB Issue
PostPosted: September 25th, 2010, 13:20
Howdy...
My first post here, and, please forgive me for any newbie terminology failures. :wink:
I have a Maxtor DiamondMax Plus 8 40GB hard drive that has a blown motor IC.
My question is two-fold...
Will replacing the PCB allow me to get to the the data (with a specialized utility, if necessary)?
If this is possible, how many of the following numbers have to match, and which ones can be different ?
  • Model # (6E040L0510214-ABA K,G,M,A)
  • Code (NAR61590)
  • Firmware(?) # (B6FEB)
  • Main IC # (ARDENT C5-C1 040111500 ARDENT-C5C1-840UK)
  • Motor IC # (Texas Instruments SH6782B) (damaged)
I'm trying to find one as exact as possible, but so far the closest I've come across has a different Texas Instruments motor IC # than what I have.
I know the drive spins up, because I bought a near match board, but it freezes at boot (though it sees the drive is hooked up).
Even though I have a half-decent soldering station with multiple tips (MetCal), I don't think I'd have a good chance of success attempting to replace the motor IC myself (unless you guys have done it successfully, then I might try it, if no other option).
I'd be grateful for any suggestions, and I appreciate your time.
Thanks in advance... :D
 Post subject: Re: Maxtor Diamond Max 8 Plus PCB Issue
PostPosted: September 25th, 2010, 13:53
B6FEB Should be fine.
If you can read the correct model number in your BIOS with the NEW PCB I think it's a match.
It could have bad sectors which could cause it to freeze on boot or SMART issue which would be firmware error (Drive should still work for recovery)
PostPosted: September 25th, 2010, 23:07
Thanks for your reply.
That's probably why the replacement board I acquired spun it up, but froze @ BIOS... it's a B4FEA (noob fail ;) ).
I think I can find a B6FEB, but the motor IC (and likely the main IC as well), would be different. The code, model #, capacity, etc., however, would be the same as what I'm trying to replace.
Would this do the trick, do you think?
I REALLY appreciate your help.
PostPosted: September 25th, 2010, 23:23
It's not the board unless they gave you a defective one. Try another one identical if you can, then if the result is the same there is another problem - internal.
PostPosted: September 26th, 2010, 3:26
agree with ST
Users browsing this forum: No registered users and 97 guests
