 Post subject: Help with a dead Western Digital WD5000AAVS - 00ZTB0
PostPosted: September 28th, 2010, 16:58
Hi All,
My WD5000AAVS - 00ZTB0 gave up on me Yesterday, it doesn´t even spin up, it gets warm nothing more.
Here in Sweden it will cost me up to $1500 to get it fixed. Can it be fixed cheaper?!
Is it possible to fixed a drive with these symptom for rookie?
I am working in a ISO 5, class 100, clean room, is this clean enough to open up at HDD?
Thanks you in advance!
Joakim
 Post subject: Re: Help with a dead Western Digital WD5000AAVS - 00ZTB0
PostPosted: September 28th, 2010, 17:31
DO NOT OPEN THE DRIVE!!!! Open the drive as the last option...
PostPosted: September 28th, 2010, 17:38
It could be a PCB problem, if your drive does not spin up or make any noise.
www.datarecoveryne.com
PostPosted: September 29th, 2010, 4:41
Agree.
Contact "mr_spokk" (Bosse) on the forum, he's in Sweden and should be able to sort you out.
PostPosted: September 29th, 2010, 5:16
Yes it is, but the disk should only be opened by a skilled professional. I agree with others here, it could be the PCB that is the cause of your problems.
PostPosted: September 29th, 2010, 7:16
Maybe you can find (on local ebay or similar) exactly the same model (working, may have bad blocks) and try to swap the PCB.
data recovery Poland
PostPosted: September 29th, 2010, 7:56
It's not possible to just swap the PCB. It will not work.
Users browsing this forum: No registered users and 294 guests
