Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: seagate ST380215AS
PostPosted: September 28th, 2010, 12:26
Ideas : few AND confused.
PostPosted: September 28th, 2010, 12:49
1024k x 16 DRAM
NHAWK - 1_Disk S-42 03-27-07_11:48
HM SFI
ERR A6: App Code
F>y
PhysCyl GrayCyl
1st Sys Cyl 00013AF1 00014615
1st 0 Offset Cyl 00013AFB 0001461F
1st App Code Cyl 00013B07 0001462B
2nd App Code Cyl 00013B09 0001462D
2nd 0 Offset Cyl 00013B15 00014639
3rd App Code Cyl 00013B21 00014645
4th App Code Cyl 00013B23 00014647
Last System Cyl 00016B16 0001763A
F>j
ERR 2E: App Code
F>R
Code - A6 Track 13B07.0.238 Sns FFF
fxxxx: Program the FlashROM AT- or CERT-built code stored on the reserved tracks
xxxx = AAAA Flash with AT (customer) code
xxxx = CCCC Flash with CERT (factory) code
F>fAAAA
Command Inactive - No VALID Cert Code Detected
ctrl+r is not working (to load cert code)
PostPosted: September 28th, 2010, 13:05
I am starting to suspect that the proper approach is to use Google translate to open accounts on the Russian and Chinese sites, and then ask such questions there, and hope that the translated text doesn't get warped into something like " I'm going to have sex with your wife and chop your head off with a machete' '. Answers do appear to be obtainable there for those who ask. Particularly the Chinese sites.
j,,1 appears to reload and reset and bring back F>. Did you try to load the cert fCCC, then j,,1? Did you try switching to T> after the load? No where have I seen j,,1 documented, but it appears in series of commands in the Russian and Chinese sites. Someone there said it resets the drive.
Like I said, i am not the expert, if it toasts your drive well I said it might...
http://www.youtube.com/user/TerraformingMaster
PostPosted: September 28th, 2010, 13:14
I think i saw that Seagate Terminal has a command to test and repair the factory tracks. Can take up to 72 hours...
PostPosted: September 28th, 2010, 19:18
Most new Seagate drives will be changed over to the new test platform (Still use serial port but no ascii). Which means no terminal access unless you have proper diag SW. Which people won't.
And I am sure its changed because of the open for all that now prevails.
PostPosted: September 28th, 2010, 19:35
Does this mean that, in future, only those select few who are privy to the fruits of industrial espionage will have terminal access? ;-)
Or are we to believe that the intricate details will be uncovered purely through painstaking reverse engineering?
PostPosted: September 28th, 2010, 19:56
The chinese reverse engineered the Eiffel Tower(It is a full sized, exact dimension and same metal construction as the one in lovely Paris) -- the new Serial output should be a piece of pie for them..
Free Solutions
PostPosted: September 28th, 2010, 20:28
IMHO, the Russians are probably the best reverse engineers. Or maybe it's just that they are the only ones that publish their work in the English language.
Anyway, it's a shame that they have a KGB goon in the Kremlin. That would be like having J. Edgar Hoover in the White House. If they ever get rid of their old guard, the Russians are going to be technology leaders. The Chinese will only ever be hit-and-run merchants, with no long term business strategies. You can't build a corporation founded on nepotism and corruption.
PostPosted: September 28th, 2010, 20:46
This is for Ux drives only
PostPosted: September 28th, 2010, 20:52
It's because USSR had maybe the best schools in the world (waaay better than US schools) and they were free, so there are more educated people in todays Russia than in any other places
But not anymore
Chinese, Japanese and Korean schools are good too BTW
PostPosted: September 29th, 2010, 2:44
I think it also depends upon the person who is being educated, not just the educational framework.
PostPosted: September 29th, 2010, 5:43
I wouldnt want to send my children to Russian Schools. Not alone let them live there. Sure Moscow, Petersburg all the large towns are fantastic.. But go a bit in land and youll be shocked... Sure its better now than it used to be.. is it?
I think most of these Eastern Block guys are only good at what they do because they did it their whole life and dedicated everything todo it.. because there was nothing else todo really.. Sit outside and have some vodka with his dad and his buddies sat on the dud bomb shell.. I might be a bit extreme.. but this is a slowly fading reality in Polish areas..
At university i have met allot of Chinese and Japanese guys doing computer science degrees.. Some of them did bio chemistry on the side because they were bored of engineering cpu's... I have not met any Russians .. so i could be biased.
Free Solutions
PostPosted: September 29th, 2010, 8:21
Also noticed that. One thing I picked up is that google translates the Russian for 'drive' into 'screw' in English if I'm not mistaken or that's what I'm assuming.
PostPosted: September 29th, 2010, 9:11
I have been to Russian villages. Fun, clever and friendly people everywhere :O) The toilets, roads and bloody bus drivers need some work granted but other than that it's not that bad.
PostPosted: September 29th, 2010, 11:08
Well if your from "Cosmos" i believe any country is fairly nice to quite good.. You should go and visit some places near Chernobyl! I'd love to know your opinion then.
Free Solutions
PostPosted: September 29th, 2010, 11:14
ppumkin wrote:
That's in Ukraine, not Russia :twisted:
PostPosted: September 29th, 2010, 11:24
Spindles into screws, platters into pancakes...
PostPosted: September 29th, 2010, 11:26
http://www.thedoorshortfilm.com/thefilm.html
PostPosted: September 29th, 2010, 12:18
I have been to Ukraine on many occasions, most are just as friendly. They even offer tours to Chernobyl if you want ;o)
PostPosted: September 29th, 2010, 12:29
http://www.kiddofspeed.com/chapter1.html
Users browsing this forum: Majestic-12 [Bot] and 75 guests
