 Post subject: Disk Management says: Status:Unreadable, File system: Unknow
PostPosted: September 28th, 2010, 19:39
Hi.
I am struggling since yesterday with my external drive (SATA laptop USB disk).
I tried with many computers.
when i plug it, I can see the new diveice on the computer but not letter is assigned to it.
When i got to XP Device Manager, I can see the drive but the status is unreadable. Is there anything i can do for it?
This dive contains all my data and i have to access them.
Disk Management says: Status:Unreadable, File system: Unknown
I tried testDisk but testDisk cannot see the drive.
Help please
 Post subject: Re: Disk Management says: Status:Unreadable, File system: Unknow
PostPosted: September 28th, 2010, 19:45
Don't run any test disk on it- especially the windows xp versions. Dont format it or initialise it.
Does it report a correct size? Is the model number displaying correctly? If so,
You will need to first run a program like R-Studio and scan your hard drive for lost files/partitions.
That should help you.
What make and model is it? Possibly the model number you can see in the device manager can help us too not just the enclosure model number
Free Solutions
PostPosted: September 28th, 2010, 19:57
Here it is:
Initio USB Device
USBSTOR\DiskInitio__________________1.06
USBSTOR\Initio__________________1
USBSTOR\GenDisk
GenDisk
ppumkin, waiting for instructions
PostPosted: September 28th, 2010, 20:00
Not much information there. It seems like its not getting info from the HDD.
Im to bed now.. 1 am mate for me.. somebody else might help you shortly to further diagnose.
Free Solutions
PostPosted: September 28th, 2010, 20:04
Please Don't go to bed.
what about the brotherwood?
What shou i do now?
PostPosted: September 28th, 2010, 20:45
The Initio device is the USB-SATA bridge IC on the little bridge board inside the enclosure. Windows is detecting the bridge rather than the hard drive behind it. If you don't mind voiding your warranty, you can remove the drive from the enclosure and install it in another USB SATA enclosure.
You can see the Initio device using Microsoft's UVCView utility:
http://www.users.on.net/~fzabkar/USB_ID ... ew.x86.exe
Some Western Digital drives incorporate the USB port on the drive itself, in which case this will pose a problem for you.
Can you show us photos of the insides of your enclosure?
PostPosted: September 28th, 2010, 21:38
ok. Will find a case and test it and give you feedback. I will do it in 6 hours time.
PostPosted: September 29th, 2010, 18:46
Hi guys.
I put the disk in another box.
Now the partion is show Not Allocated (previously it was not showing anything).
It is displaying a size too.
But the disk status is still Unreadable and Partition Type is Unknown.
Help please
PostPosted: September 29th, 2010, 18:47
Model and SN of the original enclosure?
PostPosted: September 29th, 2010, 18:56
Initio USB Device
Can't see no SN
PostPosted: September 29th, 2010, 19:18
Brand and Serial number of the hard drive itself?
PostPosted: September 29th, 2010, 19:26
WESTERN DIGITAL WD Scorpio
SN WXEY07F23158
PostPosted: September 29th, 2010, 19:30
Hmm, not what I was thinking,, did you try running TestDisk on the drive connected through the new enclosure?
PostPosted: September 29th, 2010, 19:37
yes. it is saying : read error
PostPosted: September 29th, 2010, 19:41
Hard to remotely diag for me, but I am going to say this one isn't a DIY
PostPosted: September 29th, 2010, 19:44
what is a DIY?
PostPosted: September 29th, 2010, 19:45
You probably need professional help with this one
PostPosted: September 29th, 2010, 19:56
With respect, I think this problem is beyond your capabilities. :-(
However, as a last gasp, could you upload the output of the following SMART utilities?
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/
HDDScan for Windows:
http://hddscan.com/
I suspect that your drive has a physical rather than logical fault, but could we see the partition table and boot sector with Microsoft's Sector Inspector?
http://www.users.on.net/~fzabkar/SecInspect.zip
Extract the above archive to the one folder and execute the SIrun.bat file. The procedure will generate a report file named SIout.txt which you can then upload to this forum.
For an explanation of DIY, see http://en.wikipedia.org/wiki/Do_it_yourself. :-)
PostPosted: September 29th, 2010, 20:06
Date and time:
30/09/2010
00:05
0001.033
Sector Inspector Copyright Microsoft Corporation 2003
Error 5 was encountered while opening \\.\PHYSICALDRIVE0.
Accès refusé.
SectIns
Error 5 was encountered while opening \\.\PHYSICALDRIVE1.
Accès refusé.
Error 5 was encountered while opening \\.\PHYSICALDRIVE2.
Accès refusé.
PostPosted: September 30th, 2010, 3:45
SN WXEY07F23158
Does it have XXXXXs on label ... ? :mrgreen:
Users browsing this forum: Google [Bot] and 270 guests
