 Post subject: Seagate 7200.11 ST3750630AS
PostPosted: October 2nd, 2010, 11:56
Hi
I have this disk, that was ons a USB enclosure and it fell down.
It's doing a bbzzz-bzzz, I think it's spindle (check the image of Power Situation)
Connected to the Doctor it's found, but always busy.
Tried to do the ES.2 Solution, but i get always this on terminal:
F3 T>/2
F3 2>Z
LED:000000CE FAddr:002802A1
F3 T>/2
F3 2>U
F3 T>/1
F3 1>N1
LED:000000CE FAddr:0028DFBB
What's the answer??
ACELab partner
 Post subject: Re: Seagate 7200.11 ST3750630AS
PostPosted: October 2nd, 2010, 12:24
Whats the Firmware?
Free Solutions
PostPosted: October 2nd, 2010, 12:30
FW: LC11
ACELab partner
PostPosted: October 2nd, 2010, 13:11
No amount of terminal jiggery-pokery is gonna fix a stuck spindle!
SD is picking up the model and s/n from the PCB.
PostPosted: October 2nd, 2010, 13:59
pclab wrote:
Hi
That's what I tought...
ACELab partner
PostPosted: October 2nd, 2010, 18:02
12V current = 0 mV ?????
PostPosted: October 3rd, 2010, 2:09
Clean room work required...
PostPosted: October 3rd, 2010, 5:11
lol SD's trying to say 0 mA on 12 volt
PostPosted: October 3rd, 2010, 5:12
sometimes means HDD IS eat up high current
from power output of the device
(damage old and out of spec resistors or stuck / weak motors,...) .
It suppose to cut of power as a protection measure
usually the controller IC runs very hot in this case
however the drive may still work supplying enough current
if not stuck depending on situation.
PostPosted: October 6th, 2010, 6:51
http://translate.googleusercontent.com/ ... wsY6j7v3Mw
(Grinding off the bearing cap or wedging bearing)
Does this work on only the Barracuda IV? Could you fill a replacement cap with grease and epoxy it onto such a drive, and reliably use the drive?
http://www.youtube.com/user/TerraformingMaster
PostPosted: October 6th, 2010, 7:35
Try it and let us know ;)
PostPosted: October 8th, 2010, 4:54
just make sure that it has noway to leak reach platers.
Is that an actual DR guide?
I think you got some seconds before leakage
if you use solid hart temp. grease.
PostPosted: October 8th, 2010, 5:57
Yes, it's a recommended procedure, straight from Ace Labs.
"Customer support PC-3000"
"Seagate Barracuda IV:: wedging bearing"
PostPosted: October 8th, 2010, 7:41
But there are much safer and more efficient options to deal with this fault
PostPosted: October 8th, 2010, 8:27
'recommended' ? Maybe in some case not in general. Ah, ATA IV , not else...
Users browsing this forum: No registered users and 95 guests
