 Post subject: Need PCB for Seagate ST32000542AS
PostPosted: October 5th, 2010, 16:54
100536501 RevA
B5502C30
SH6968B
Any help would be greatly appreciated. I found one with everything matching except it had B5502C20 which won't work. Thanks.
 Post subject: Re: Need PCB for Seagate ST32000542AS
PostPosted: October 5th, 2010, 17:05
I do not have one handy but I am almost positive that with just the 100536501 RevA you can swap the firmware chip in the upper left of the board.
Just doing a regular board swap will not work with a dead board on these models.
if the drive is not spinning at all i would do a search on TVS on this board
PostPosted: October 5th, 2010, 17:07
Doesn't matter how close you get with f/w version, it won't work.
These PCB's have UNIQUE data (even down to the serial number) programmed into the ROM chip which needs to be transferred.
PostPosted: October 8th, 2010, 6:17
If you need to purchase a PCB, try the following vendor:
http://www.onepcbsolution.com/
His price is US$40, plus $10 for a ROM transfer, if required.
Otherwise, upload a detailed photo of your PCB and one of us will help you with a DIY repair, if feasible.
BTW, I am not associated with any supplier.
Users browsing this forum: Google [Bot] and 80 guests
