 Post subject: Help with Hitachi HDT725032VLAT80
PostPosted: October 5th, 2010, 18:29
Hi Friends,
I've got a defective Hitachi HDT725032VLAT80.
The drive is starting, but stays busy, while the heads make small clicking noises. Not a hard click as when a head is broken, but small clicks as it is recalibrating.
I had an exact donor and so I try:
- Swapped pcb: go to ready but I can't access to SA. I can't use "Dynamic Repair" on SalvationData HD Doctor.
- Changed nvram on the pcb: stays busy
- Changed HEAD: stays busy and the same small clicking.
Anyone has a suggestion to get it working ?
Thanks in advanced,
Leonardo.
 Post subject: Re: Help with Hitachi HDT725032VLAT80
PostPosted: October 6th, 2010, 5:44
First of all, a precise diagnose is needed.
For this, you should have tools and not only toys, and knowledge.
I can recover this drive, but not remotely.
PM me if interested.
Janos
PostPosted: October 7th, 2010, 4:10
Here are some suggestions:
Never buy or use any Hitachi hard drive in your life, why?
Here's why:
1. Then are manufactured poorly, and do tend to break when you least expect them to.
2. I recently was using a Hitachi hard drive, then right after I backed up my most important data, the hard drive started clicking. I was "extremely" lucky just 10 minutes or so before the hard drive completely died.
3. I do not know wheither you may or may not know this, but I am sure other hard drive manufacturing companies do not do manufacture hard drives with such specifications as the one I am about to mention below:
After the laptop hard drive went dead, I played with it some, then opened it up and saw that the problem was with the read/write heads. Then after I plugged in the hard drive through the laptop external case, while it was open, I used a small screw driver to make sure no data could ever be recovered (I made many lines in many circles - NOTE: Do Not Attempt to do the same. Why? Here's why:).
So later on, this is what I discovered: Then I took the disk inside the hard drive off with a torx screwdrive, and tried to bent the disk over the trash can, and all of a sudden "snap" the disk broke. And it was actually "made out of glass" and not metal, like other companies do so.
I "never expected" anything like this. Because this is a very cheap was to manufacture hard drives, which in-case of serious data loss, is like having your data on a piece of paper, which is guaranteed un-recoverable (i.e. example: you drop the laptop hard drive from big height and the disk glass breaks - which "is the actual disk inside the hard drive").
So I would never ever again use any Hitachi hard drives, just in-case my data does not become "nothing".
Note: These are just my suggestions, and they differ from one person to another person. Therefore, please do not take them seriously.
Thank you very much.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 198 guests
