Forum rules
 Post subject: PCB USB native
PostPosted: October 6th, 2010, 11:20
Hi to all!
Please squem solder sata conector in pcb..
:mrgreen:
Нет ничего невозможного
 Post subject: Re: PCB USB native
PostPosted: October 7th, 2010, 14:08
sempre wrote:
Hi to all!
:mrgreen:
Where can I find the adapter? :?: (usb-sata-pata) know in pc3k UDMA has ... to buy just the adapter
PostPosted: October 7th, 2010, 14:11
There is no such adapter. You have to do modifications yourself.
Murphy was an optimist
PostPosted: October 8th, 2010, 5:39
The underside of the board has the USB-SATA bridge chip. The two long pairs of capacitively coupled tracks are the SATA Tx/Rx pairs.
If the chip is a JMicron JM20339, then see this reference design for pinouts:
http://www.hxwtek.com/upload/jm20329_st ... 20open.pdf
PostPosted: October 8th, 2010, 15:11
Thanks for help!
Look chip.
PostPosted: October 8th, 2010, 16:26
I guess you know what to do. However, for those that don't, you need to remove the four coupling capacitors, and run four individual wires from the MCU side of each capacitor to a SATA connector.
PostPosted: October 8th, 2010, 16:41
Remove these capacitors?
Squem PCB?
:mrgreen:
PostPosted: October 8th, 2010, 17:01
Sorry, the schematic was for a JM20329 which has a different pinout. However, the principle should be the same for the JM20339.
I have identified the capacitors here:
http://www.users.on.net/~fzabkar/HDD/JM20339_Tx_Rx.jpg
I believe the pins should be laid out in the same order (or reverse order) as the SATA connector:
http://pinouts.ru/HD/serialATA_pinout.shtml
In fact, here is a reference design for the JM20339:
http://www.wison.com.tw/cht/document/LT ... 9-V1.2.pdf
... and a datasheet:
http://www.wison.com.tw/cht/document/LT ... 061012.pdf
PostPosted: October 8th, 2010, 17:17
THANKS!! :mrgreen:
