 Post subject: Hitachi Travelstar HTS541060G9SA00 Not Detected
PostPosted: October 20th, 2010, 12:40
Hi all,
I have a notebook by Compaq nx6325 with mobile data protection system and the hard drive (Hitachi Travelstar HTS541060G9SA00) died.
I have tried to access the hard drive via using an external enclosure case and all it does was making a slight clicking noise as if it was trying to spin up.
Any suggestions to recover the data?
 Post subject: Re: Hitachi Travelstar HTS541060G9SA00 Not Detected
PostPosted: October 20th, 2010, 12:58
Clicking? Take it to a pro
PostPosted: October 20th, 2010, 13:07
clicking noise is most likely the heads timing out and coming back to parking ramp hitting the stopper. I bet the drives spins just fine. Sry m8. Need proper diagnostics and chances of easy DIY are very slim.
Ninja Edit. I dont really like these drives... They come to the shop a lot with bad heads and/or full of bad sectors. It is possible that the drive clicks for you cause of the bads, in that situation recovery might not be very expensive.
PostPosted: October 20th, 2010, 13:26
Thanks for the suggestions.
I don't have anything important on it. Just want to know how to recover data the DIY way.
It makes a humming noise on and off.
PostPosted: October 20th, 2010, 14:17
ok well, i dont mind =) Record the audio of ur drive as you apply power to it and upload it here.
PostPosted: October 20th, 2010, 15:12
This is what everyone says :mrgreen:
PostPosted: October 20th, 2010, 19:00
Sounds like stiction.
See this thread, but heed the warnings:
http://forums.seagate.com/t5/FreeAgent- ... 242#M11384
Users browsing this forum: No registered users and 198 guests
