 Post subject: Replace SMBJ12A by SMBJ13A
PostPosted: October 18th, 2010, 11:21
I was wondering if i could replace my tvs 12v diode marked LEK from ON Semiconductors (which is a SMBJ12A) with a tvs diode from a old hard drive marked BUF from st semiconductor (this is a SMBJ13A)
I'm just not sure, they both protect the 12v rail so it should be ok?
Thanks Nick
 Post subject: Re: Replace SMBJ12A by SMBJ13A
PostPosted: October 19th, 2010, 4:00
Yes, should work. However, be carefull there is no other short circuit in the pcb.
Better use a bench top power supply to test.
Dobre
Murphy was an optimist
PostPosted: October 19th, 2010, 11:13
i don't think there is a other shortage in my pcb, checked all the resitors, none of them are faulty...
i use a power supply that has a good and steady 12v, and if there is a shortage it shuts down. Someone making pcb boards for his job will replace it for me.
will report back on sunday.
Thanks, Nick
PostPosted: October 19th, 2010, 22:29
The SMBJ13A has a higher breakdown voltage than the SMBJ12A. Both provide overvoltage protection, but the latter would have a better safety margin.
PostPosted: October 22nd, 2010, 2:55
Would 1 extra volt affect my hdd?
Nick
PostPosted: October 22nd, 2010, 3:18
This is a protection circuit. It only intervenes in case the power supply of you PC breaks down, so it wont make much difference for normal functionning of your drive.
Dobre
PostPosted: October 22nd, 2010, 5:43
Yes, i mean, when the powersupply would fail, would that extra volt damage the hard drive?
got myself a new powersupply so no worries about that.
Nick
PostPosted: October 22nd, 2010, 7:31
No.
Dobre
PostPosted: October 24th, 2010, 8:46
Just reporting that I got the tvs replaced with a SMBJ13A yesterday evening and all is working again !!!
Thanks again for the help, Nick
PostPosted: October 25th, 2010, 2:46
Dont trust this disk any more; copy your data to a new drive.
Dobre
Users browsing this forum: michael chiklis and 167 guests
