Forum rules
 Post subject: How to perform Firmware Update on a Samsung HM060HI?
PostPosted: November 4th, 2010, 11:52
Please someone can say me if exists a firmware tool to update the firmware on a HDD Samsung HM060HI?
My firmware's version now is YD100-15. Thanks.
 Post subject: Re: How to perform Firmware Update on a Samsung HM060HI?
PostPosted: November 4th, 2010, 12:28
Why?
PostPosted: November 4th, 2010, 14:29
Standard ATA command will do that
PostPosted: November 4th, 2010, 15:48
Abra Ka Dabra....
P.S. if the drive is working you don't need a FW update - assuming it is available.
PostPosted: November 5th, 2010, 2:09
You can use the "fwdownload" command option for hdparm under Linux.
http://www.unix.com/man-page/Linux/8/hdparm/
Tim Small documents two successful Seagate firmware updates:
https://ata.wiki.kernel.org/index.php/Talk:Known_issues
However, he cautions that "you have to be pretty sure that Linux isn't going to access the drive, or it will issue a bus reset during the firmware update process. e.g. if you need to carry out the update on a boot drive, then you could prepare the files, then reboot into single user mode, with all filesystems remounted read-only".
The man page has the following warning:
"This command (--fwdownload) is EXTREMELY DANGEROUS and HAS NEVER BEEN PROVEN TO WORK and will probably destroy both the drive and all data on it. DO NOT USE THIS COMMAND."
PostPosted: November 5th, 2010, 12:07
Did you try FOR REAL on HMxxx ? :mrgreen:
PostPosted: November 8th, 2010, 7:29
Samsung drives need a special Flasher program to flash their ROM.
VTool and WCube can be used also. Mayby HUtil (SRV) .
PostPosted: November 8th, 2010, 8:28
The problem is not the ROM it's the rest.... :D
P.S. HM060HI
PostPosted: November 8th, 2010, 9:52
That's not true.
You could use DEBUG in DOS if you had the time :o) . It's an ATA command (PART OF THE SPEC)
Finding the correct firmware is the hard part!
PostPosted: November 10th, 2010, 8:01
Samsung firmware update will rewrite ony ROM code and overlay code.
If you have some problem with SA, you should seek another method.
PostPosted: November 19th, 2010, 8:56
YF19BM54.BIN is the latest. Try to find it.
PostPosted: November 21st, 2010, 0:59
Programs and utilities for data recovery and repair hard drives:
http://www.griol.com/downloads.html
