 Post subject: I need to know how repair bad sectors !
PostPosted: November 3rd, 2010, 12:49
Hello !!
I am using your software to fix any problems inside HDD...
Follow the Documentation I scanned my HDD, it show me that my HD has 2 blocks damages, then I need to know how I can fix any sectors bad in my HD whit the software.
Thank you !!
 Post subject: Re: I need to know how repair bad sectors !
PostPosted: November 3rd, 2010, 20:06
If your data are not important, then zero-fill your drive.
Otherwise, determine which file(s), if any, occupy the bad sectors. Then delete these files and replace them with backups. The next time the OS writes to the bad sectors, they will be retested by the drive and returned to service if good, or replaced with spares if bad.
Tip: How to determine which file occupies a particular sector:
http://forums.seagate.com/t5/Barracuda- ... /m-p/35567
PostPosted: November 4th, 2010, 17:12
i have used and tried hdd regenerator and it works! it is included in hirens boot disk
PostPosted: November 4th, 2010, 17:56
Even better : I have put a disk under the saddle and after a day riding galloping , jumping fences and going around, there were no bad sectors anymore :mrgreen:
PostPosted: November 4th, 2010, 18:41
And again... Another good time to be....
ACELab partner
PostPosted: November 4th, 2010, 23:33
Go here and download MHDD. There is instructions on this one too. Scan your drive and remap the bad sectors so they are blocked and can not be used again. After you run this then zero fill your drive. Read this book and use this program and you should arrive at where you want to be.
Iorana Haraharaini
PostPosted: November 5th, 2010, 0:26
and if doesn't work, refer to the nearest pro.
Users browsing this forum: No registered users and 147 guests
