 Post subject: Seagate 'Cuda ES.2 500Gb spins - not boot
PostPosted: November 5th, 2010, 23:01
Hallo all :
new guy here - did a search and have a few questions .
HDD ( ST3500320NS - firmware SN04 ) just crashed - spins but no boot - not recognized -
I see maybe a firmware issue or the circuit board issue - which way to go - I think try to find same used version in working order and swap the board to see at least if I can recover data - how much luck will I find in this endeavor ?
or a new PCB - seems like a waste if all I wish to do is grab data and trash - yes /no/maybe ???
dont understand how a firmware issue would effect me when I have been working this HDD for 16 hr daily for at least 9 months - i live in a hot dry climate so figure heat just got to it in the end
looking just to recover and trash - 2nd Seagate crashed
if you can lend some advise on how to proceed - appreciate your efforts and time
cheers in advance -
 Post subject: Re: Seagate 'Cuda ES.2 500Gb spins - not boot
PostPosted: November 6th, 2010, 17:27
If it spins, it's probably not a PCB issue. Instead the symptoms are consistent with the 7200.11 BSY firmware bug.
See this thread:
http://forums.seagate.com/t5/ATA-and-Se ... 036#M19464
... and this one:
http://www.msfn.org/board/topic/129551- ... ge__st__20
Here is the appropriate Seagate tech bulletin:
http://www.expreview.com/img/topic/seag ... Update.pdf
PostPosted: November 6th, 2010, 18:31
cheers fzabkar:
been calling about and reading a bunch -
now the issue is can I retrieve the data off this brick myself with the self help sites ?
I am Mac user - so dunno if this will complicate the issue more
cheers;
PostPosted: November 6th, 2010, 19:27
Once you repair the drive, it will be back to normal, ie your data will be intact.
I'm not a Mac user, but you should be able to apply the same procedure using a Mac based terminal emulation utility.
You may first want to check whether Seagate will fix your drive for free.
PostPosted: November 6th, 2010, 20:54
say fzebkar:
Cheers again ;
according to Seagate the drive is under warranty - they ask me to back up drive ( seems impossible ) - rather grab the data if possible and send to repair an empty drive - dont know what the trust issue would be with data at Seagate
cheers:
PostPosted: November 6th, 2010, 21:05
You need to contact the right people at Seagate. They may be treating yours as an ordinary warranty case, in which case your data will not be saved.
The following thread discusses other people's experiences.
HOW TO FIX BRICKED DRIVES WITH SEAGATE TECH SUPPORT:
http://forums.seagate.com/t5/Barracuda- ... /m-p/23941
Users browsing this forum: Google [Bot] and 213 guests
