 Post subject: ST31000AS 1Tb hungs POST...
PostPosted: November 8th, 2010, 3:29
Hi every1! I have ST31000340AS 1TB. Age - about 1 year. Recently i came home, tried to turn on my pc and it hung at POST. Well, I waited til something happens - it was not detected, though pc continued loading (i have os installed on a different HDD) after some 40-50 seconds.
I`ve checked if it was seen by windows device manager - nope. Downloaded SeaTools, and guess what.. It showed me that I have 4 HDDs (yeah, i have them, 4 all in all, WD as a system disk, two old ST3200827AS 200G and this ST31000340AS), but what was interesting - it showed me this - WD, and THREE identical ST3200827AS, two of them have S/N 4ND28WD9, and the fourth - 4ND280SG, firmware`s 3.AAE....
As i unplugged it and tried to run the test again - it showed me the same 4 HDDs, though only 3 were connected...
The thing is I could send it to hell, go get the new one and avoid bothering you, but it still has some 700 gigs of working data collected for 6 years on it and don`t want to lose it at all. Any thoughts?
 Post subject: Re: ST31000AS 1Tb hungs POST...
PostPosted: November 8th, 2010, 4:08
Your drive may be a victim of the 7200.11 BSY bug.
If so, then see this thread for an easy DIY fix:
http://forums.seagate.com/t5/ATA-and-Se ... 036#M19464
Here is the appropriate Seagate tech bulletin:
http://www.expreview.com/img/topic/seag ... Update.pdf
I suggest you first contact Seagate and ask whether your drive qualifies for free data recovery.
PostPosted: November 8th, 2010, 4:31
damn on seagate, one more victim
PostPosted: November 8th, 2010, 7:44
Thanks, man! BTW, is there any option like "go buy the same new model, and simply replace the PCB", if the issue is in the electronics part? Could it be easier? And I didn`t get one thing - they say I`ll need to kinda format it, restore the partition. Will it affect the data? or just recreate the partition, boot sector or whats there, without touching it?
PostPosted: November 8th, 2010, 16:01
If the drive spins up, then it is most likely not a PCB problem. Otherwise, when replacing the PCB you need to transfer the 8-pin serial EEPROM chip from patient to donor. This chip stores unique, drive specific calibration data.
These URLs should help you identify the components:
http://hddscan.com/doc/HDD_from_inside.html
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
http://www.users.on.net/~fzabkar/HDD/TVS_diodes.txt
This vendor offers a board for US$40 plus $10 for a ROM transfer:
http://www.onepcbsolution.com
Here is another:
http://www.hdd-parts.com/seagate-barrac ... -sata.html
As for your partition question, the procedure doesn't touch your data. The "partition" being referred to is in a reserved area on the platters.
PostPosted: November 30th, 2010, 0:53
Thank you, fzabkar, veryyyyyy much! Recently I did all the stuff, it worked properly and now I`m happy =))) Thanks a lot.
Users browsing this forum: No registered users and 137 guests
