Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: October 17th, 2010, 17:22
hamed_gibago wrote:
this is my 22.bin file when i ran the scripts in mhdd
but my hard is maxtor STM3250310AS
when i ran .dump .dump2 and .dump48
at last i get the error: No DRQ
what should i do?
this is my 22.bin after running it:
This dump is from a Western Digital drive, not a Maxtor/Seagate.
PostPosted: October 18th, 2010, 0:51
what should i do?
so what should i do?
fzabkar put a link for me, but i didn't find anything helpfull there
I'm so bored of searching and I cant find the way to unlock my hard
please help anybody me
PostPosted: October 18th, 2010, 2:31
well, i guess that there is a website where you can read download the software and connect your HDD and see if its supported or not, they will do it online but i dono how much u should pay for that
try it
PostPosted: October 18th, 2010, 4:22
Use SeDiv to read the Vendor Track, assuming it supports your particular model.
Then someone may be able to analyse the data for you.
PostPosted: October 18th, 2010, 8:47
try it
ok
you just guess?
tell me the website
PostPosted: October 18th, 2010, 9:01
hamed_gibago wrote:
try it
ok
you just guess?
tell me the website
u will find it here if u spend some time searching , i posted it many times
look @ my posts about ur password issue
PostPosted: October 18th, 2010, 16:35
this is my log file from victoria 4.3 freeware beta version:
please help me to get the password
is this the correct file?
PostPosted: October 19th, 2010, 3:13
Now this is starting to get annoying........
The topic in this thread is Western Digital password removal. It has nothing to do with Maxtor or Seagate!
You have been given ideas how you might be able to diy the password so get on and do it or take it to a local recovery professional.
Oh and start your own thread instead of hijacking this one.
Search, read, then ask questions.
PostPosted: October 19th, 2010, 4:51
I suggest for this case to go to Seagate forum (on Seagate website) or call Seagate directly. I'm sure they will give all the answers.
PostPosted: November 4th, 2010, 19:36
I have a problem with running script .rm02 on WD5000avvs
I get the error "drive reports an error" and the script doesn't make no 22.bin file, could someone tell me what shall I do to succesfully run this script? i use mhdd 4.5 version, i have the cs.bin made in hex editor, i dont know what could failed?
Peter
PostPosted: November 5th, 2010, 1:24
Try one or more of the following utilities.
Utilities For Studying Service Area Of HDDs:
http://nazyura.hardw.net/000006.htm
PostPosted: November 5th, 2010, 7:07
I used marvr_r as well as ZU and nothing helped .. maybe my mainboard chipset is not suitable? or i need an sata/ide adapter? does that matter?
The drive is correctly shown in BIOS, and in mhdd eid command displays as usual, security is set on, max
Peter
PostPosted: November 5th, 2010, 16:24
I can't answer your questions. You could try contacting the author:
http://nazyura.hardw.net/000007.htm
Alternatively, try configuring the SATA controller for legacy or compatibility mode in your BIOS setup.
PostPosted: November 5th, 2010, 17:22
your in luck try WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD as MASTER password with security erase and you can unlock it "BUT YOUR / SOMEONES DATA WILL BE ERASED" "NO DATA"
PostPosted: November 5th, 2010, 17:26
LOL :lol:
PostPosted: November 6th, 2010, 16:12
guru, If I were in luck I would not write here for help :) Master password is changed by the shitty recorder hardware, so factory default master pass wont work (I tried desperatly in lack of other ideas, different lenghts, even putting in hex with victoria).
I see in this thread that someone has read his pass from wd5000avvs, but he doesnt replays private message, hope someone will help me. Pleas PM me with any clue
cheers
and respect for the gurus
Peter
Peter
PostPosted: November 6th, 2010, 16:47
http://www.hddunlock.com/drives/wd/
Your model isn't listed, but "HDD Unlock Wizard may support more drives than listed here. Please run HDD Unlock Wizard to find out whether your drive is supported — it's free ..."
Unlocking costs US$30.
PostPosted: November 10th, 2010, 15:50
Thanks fzabkar, i tried. Why does this HDD Unlock Wizard say that my drive is unsupported? OK, what's going on? Do I really am that unlucky? :/
Is it something top secret about some special SCT command set maybe???
What is your problem BlackST ??? Well, some of You are such a smartass, so why no help in this particular casus of WD5000AVVS-63M8B0
Peter
PostPosted: November 10th, 2010, 16:44
You are not unlucky . In a nutshell :
1) As previously said, there are legal implications about giving away info that can be used to gain arbitrary access to someone else's data (the fact that someone publicly released some info for a specific drive doesn't mean every day is Sunday) or potential unlawful purpose.
2) DVR disk : the locking mechanism is part of the copy protection of copyrighted material.
3) If you go to a decent DR specialist , the cost of the unlocking will be few EUR /$ BUT probably you have to sign something about property of the disk AND/OR limitation of responsibility as nobody want to have troubles for few $/EUR. At least for me it happens, and all my colleagues I know for sure they do the same. Sorry, but this is not Far West.
4) This is not Far West neither a call center. You can ask but if you don't get any answer, either because MANY people CAN'T and the other DON'T WANT TO give an answer, there's nothing you can do.
Of course I know and all the pros know how to solve your question, simply probably was decided that it is not possible or worth or sane or legal or whatelse to give the answer. At least at present and here.
Personally I do not endorse the dispersal of information, but it's me. I don't care about the rest or what other people do.
Suggestion : go to WD site forum and ask the same question.
PostPosted: November 11th, 2010, 5:58
I suspect that your model stores the password in the same place as other similar models, but perhaps the author of HDD Unlock forgot to include it. It may be worth contacting him/her.
Users browsing this forum: No registered users and 99 guests
