 Post subject: Hdd guru help.
PostPosted: November 18th, 2010, 15:48
Hdd guru won't recognize hard drive, I want to format to install windows7 instead of vista, and hdd guru, will not recognize the drive, any sugestions anybody?
 Post subject: Re: Hdd guru help.
PostPosted: November 18th, 2010, 16:13
How old is your drive?
Manufacturer and model of the drive?
If its old, get a new one.
Does your BIOS recognize that drive?
Jumper/s set correctly?
www.datarecoveryne.com
PostPosted: November 18th, 2010, 16:54
It's a new HD, it's a sata drive, Bios doe's recognize it, thanks for your quick reply.
PostPosted: November 18th, 2010, 20:37
If you install an OS you can choose to make a fresh install and usually delete any existing partitions on the hdd.. ?!
You should also consider giving more information about what drive you got there, what it's actual status is, the environment (what do you try to do) and how it got into that status..
I mean, you want help. We don't have to pull every detail out of your nose to get you there.
Users browsing this forum: Google [Bot] and 135 guests
