 Post subject: rattle sound of hard
PostPosted: December 1st, 2010, 11:18
hi
give hard rattel sound. 1 reason maybe there are badsector . for test this probability i want low level format az completely and slove this problem. so i ask az you introduce powerful software to low level foramt disk and repair badsector.
thanks
 Post subject: Re: rattle sound of hard
PostPosted: December 1st, 2010, 11:25
If the drive is clicking, it has worse problems than just bad sectors
PostPosted: December 1st, 2010, 11:44
if problem not bad sector !! maybe az board of hard or ...............
how board test ?
if dident attention to this sound are possibel more worse problem ?
PostPosted: December 1st, 2010, 23:49
how do i fix the problem ?
PostPosted: December 2nd, 2010, 0:51
Give some more information"
1. What kind of a drive is it
2. Rattle sound maybe make a recording so we can hear it
Very confussing what you want. If it is heads then they need to be changed. but then it is dropped it is another issues. How did it get like it is now. Does your Bios see it? What do you want. You try to LLF your drive and what does it do stop in the process of this one. You want a software to do a power recycle when it is running. Is this what you want?
To tell you the truth if you are trying to LLF your drive it might be better to just buy a new one and go on they are cheap on this
Iorana Haraharaini
PostPosted: December 2nd, 2010, 11:42
kind of a drive is maxtor.
and when turn on computer rattel sound is begin and not chang.
im first want low lovel format az boot . plz introduce powerful software to low level foramt
thanks
PostPosted: December 2nd, 2010, 12:26
It will not work or help you out. There is none to do this for you unless you have tools to work with that can check on this drive. You need a new HDD.
Iorana Haraharaini
PostPosted: December 2nd, 2010, 15:27
i run software " hard drive lnspector "
report represent this message :
time between ecc-corrcted errors . It goes up and down , low is brobably bad.
what mean this message ? and how fix this problem ?
tnk
Users browsing this forum: Google [Bot] and 285 guests
