 Post subject: Western Digital WD10EAVS faulty - please help
PostPosted: December 8th, 2010, 15:47
This WD WD10EAVS 1Tb was in a WD MyBook but it stopped working, no noise, no smell just as dead as a dodo.
Upon testing the power supply I found it was supplying 20V instead of 12V, so I guess this is the cause.
I'd like to get a similar logic board and replace it but apparently you need to swap the U12 ROM chip. My board has not got a U12 ROM chip so any ideas would be appreciated.
Also I've removed diodes D3 and D4 (I read that this might work) but still no good.
Ideas please!
 Post subject: Re: Western Digital WD10EAVS faulty - please help
PostPosted: December 9th, 2010, 7:31
Nothing you can do without specialist tools on this one I'm afraid, the ROM info is inside the MCU (chip with the "M" on it).
A new PCB need to be "manufactured" with the correct ROM info, which can be rebuilt using the ROM images on the platters.
PM me if interested.
PostPosted: December 9th, 2010, 7:43
Hi, Did you check r67 as it looks like a fuse?
Users browsing this forum: No registered users and 158 guests
