 Post subject: WD 500BEVT-22A0RT0
PostPosted: December 8th, 2010, 14:45
Hi
I have this HD, that doesn't spin up, so it's not detected. No Strange noises, or clicking.
I tested the PCB on another WD500BEVT drive (this disk has bad heads, but spining and is detected) and it spins too, so no PCB problem, right?
I measured the motor coil resistance, and it's exactly the same between the 2 HD's.
What can this be?
ACELab partner
 Post subject: Re: WD 500BEVT-22A0RT0
PostPosted: December 8th, 2010, 15:23
I've been through this before.
PCB:
- donor PCB spins the drive, but does not come ready
- client PCB spins donor, but does not come ready
- transfer ROM to donor PCB, does not spin
Heads:
- change heads, drive has same symptoms
Motor:
- move the platters, drive still has the same symptoms
The one case I had like that, I don't recall if I ever did figure it out. I think it is on my shelf of, "must take some time to figure it out," projects.
I'd love to know if you do figure it out.
PostPosted: December 8th, 2010, 16:10
This is where you need to look.
Could be ROM is not being read properly during POST, could be that the ROM has somehow become corrupted, and the MCU is seeing it as a mismatch or something.
Read ROM contents to a file, check contents for garbage. Compare to the "working" ROM.
PostPosted: December 8th, 2010, 17:54
Hi Russwinters
The drive is not recognized. How can I read the ROM? Only if I read it on a flash reader, right?
@LCoughey
I hope to get it to :mrgreen: :mrgreen:
Thanks for your all your help.
ACELab partner
PostPosted: December 8th, 2010, 20:09
pclab wrote:
Hi Russwinters
@LCoughey
No set to kernal mode in udma. Try this one and see what happens on it.
Iorana Haraharaini
PostPosted: April 3rd, 2011, 12:06
Just remembered I had this case open.
Well: the problem was on the platters. Completely scratched :D :D
ACELab partner
Users browsing this forum: No registered users and 93 guests
