Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: HDD LLF problem -"Cannot change Visible in OnShow or On
PostPosted: December 8th, 2010, 11:18
Not sure if anybody needs this info, but the previous solution is for my Dell E4300 and that was when using the onboard Ricoh MMC/SD card reader.
No need to disable it, just ejecting the SDHC card stops the problem.
PC:C2Q Q6600@3.1Ghz|8Gb PC8500|4Tb|HD4870|G7|Razer Barracuda 5.1|win7-64
Server:Opt165@2.25Ghz|2Gb PC4000|7.5Tb|s2008-64
LaptopIBMx60|320Gb|4Gb|win7/Ubuntu10
PostPosted: December 8th, 2010, 13:50
Hi boys....... i have used recently this software on the same computer the problems appears some time ago.
This time working without problems!!
Mah....... this is the same release..... but this time working.
Ah... disable all scanner malware and antivirus during the formattation :)
PostPosted: December 9th, 2010, 3:52
Some AV software will block you from being able to edit / delete MBR's, also some BIOS "AV protection" settings will block you from writing to the Master Boot Record: my problem was not either of these.
It handles onboard SATA, eSATA and USB drives fine and I think was fine with USB pendrives being plugged in, but would not touch anythign if there was a device on the onboard Ricoh cardreader.
Users browsing this forum: No registered users and 109 guests
