 Post subject: seagate external usb hard drive problem
PostPosted: December 10th, 2010, 0:33
Hi All,
i own a sea gate external usb hard drive of 500 gb capacity.bought it a year back from usa.
Now the problem is that the drive is detectable by the laptop,but when i try to open it it is not responding at all,i tried to "error checking" but the hard drive is not responding.when i right clicked on the drive to view its properties,to my surprice its showing the used cum free space as 0 byt in blue color :shock: :shock: .I tried to recover the data by recovery sw but in vain.
Please help me in solving the issue as there is important data(320gb) in it.
1)is it possible to bring the drive alive.
2)is it possible to retrieve the data from it? if so how? and using what sw?if possible links to it.
Thanks,
kasperr.
 Post subject: Re: seagate external usb hard drive problem
PostPosted: December 10th, 2010, 6:51
Your case is probably a FW issue, so SW will not help you in this case.
If your data is valuable, best thing is to go find a DR company who can help you.
PostPosted: December 10th, 2010, 11:19
Id suggest opening up the external case ( NOT the drive ) and giving us a full model number and FW version of the drive.
PostPosted: December 11th, 2010, 23:26
Model number:PN: 9HH134-566(SN:5VE059F2)(ST9500325AS) MOMENTUS 5400.6
i have furnished the details present on the drive after removing the case.if i am wrong please me now what to see on the drive for the deatils.
Fw version number:0001BSM1
right click on the drive shows that the file system is RAW
PostPosted: December 12th, 2010, 5:18
Quite probably firmware issue.
PostPosted: December 12th, 2010, 6:31
than what is the possible solution to it?
PostPosted: December 12th, 2010, 11:06
If you don't have the right tools, you can't fix it.
Even if you have the right tools, you need the right knowledge for it.
PostPosted: December 13th, 2010, 0:14
I hope you have right knowledge to deal with this issue,Please help me in solving the issue.i am pretty much sure under your guidance i will crack this nut
Users browsing this forum: Google [Bot] and 215 guests
