 Post subject: cyclical redundancy error on hard disk wd5000aavs
PostPosted: December 10th, 2010, 10:05
i am having a crc error and the hard drive does not show up, although i can see it in windows managment console, but when i try to initialise it,,,,,,it gives a crc error.
any ideas how to fix it, using any windows program...
it is 3.5 western digital
 Post subject: Re: cyclical redundancy error on hard disk wd5000aavs
PostPosted: December 10th, 2010, 10:51
Try to clone it to another good disk. Use, for instance DMDE or ddrescue.
Any noises, clicks?
ACELab partner
PostPosted: December 10th, 2010, 11:38
slight noise sometimes, but i am trying to rescue and fix the drive, the main prority is to to get the drive running......i tried using spin rite but it does not get detected, so the best thing would be to use something in windows, okey i am going to try dd rescue though....
PostPosted: December 10th, 2010, 11:51
Sunny, Spinrite killed more drives , then Leonidas Persians. Do not use it. If cloning software does not detect the drive for you - its not a DIY case unfortunately.
PostPosted: December 10th, 2010, 13:45
then what would you recommend to save some lives and souls of the drive
PostPosted: December 10th, 2010, 15:11
if the cloning software wont detect the drive , like Pclab suggested - seek pro help. If data is not needed and you just want to fix the drive - better buy a new one.
PostPosted: December 13th, 2010, 4:43
you can try Ghost to clone your disk. if there in no major damage should propably clone it ok.
--Don't forget to go to the options and check the "ignore crc error"--
gluck
Users browsing this forum: ccc, Google [Bot] and 118 guests
