 Post subject: Samsung DVR 3200 File System
PostPosted: December 19th, 2010, 6:03
I got a case from SAMSUNG DVR 3200.
Successfully I cloned the drive, but while I checked the clone copy I saw the drive has a NTFS FORMATTED VOLUME/PARTITION, checked using GDB for NTFS (during the scan it showed files r getting detected in several sectors), after the complete scan it didn't show any files.
Any idea?
Does it carry other file system instead of NTFS?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Samsung DVR 3200 File System
PostPosted: December 19th, 2010, 6:47
Try with R-Studio i had the same problem after scanning i found UFS inside try may be same u have ...
PostPosted: December 19th, 2010, 10:46
I would use UFS Explorer, as it supports many file systems.
But anyway, you say you saw a NTFS partition. Have you checked MFT records, to see if they are there.
PostPosted: December 19th, 2010, 18:53
Why not start by examining sector 0 with a disc editor?
PostPosted: December 20th, 2010, 15:56
sorry to delay...
scan results of R-Studio
http://img813.imageshack.us/img813/2034/rstudio1.jpg
Uploaded with ImageShack.us
__________
THANK YOU
SHAHI
PostPosted: December 20th, 2010, 17:43
I also sugest USF Explorer. It was the one that solved me a problem with a DVD recorder too.
ACELab partner
PostPosted: December 20th, 2010, 19:20
Or else, post a screenshot of MBR.
PostPosted: December 21st, 2010, 1:47
Offset       0  1  2  3  4  5  6  7   8  9  A  B  C  D  E  F
000000000   6F 3D BA DE 21 F7 00 0A  00 00 00 05 00 00 00 00   o=ºÞ!÷
000000010   00 00 00 00 00 00 02 00  00 01 D1 A0 00 00 00 00             Ñ
000000020   00 00 00 00 00 80 00 00  10 00 00 00 00 00 00 00        €
000000030   00 00 00 00 00 00 00 00  00 00 E5 81 00 00 00 00             å
000000040   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
000000050   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
000000200   10 00 00 00 21 F7 00 0A  00 00 00 05 4C DE 21 F8       !÷      LÞ!ø
000000210   FF FF FF F3 05 0F 00 00  00 9F 9E 10 00 41 6A 33   ÿÿÿó     Ÿž  Aj3
000000220   10 00 00 00 21 F7 00 0A  00 00 00 05 00 00 00 00       !÷
000000230   00 00 00 00 00 00 00 00  00 00 00 00 00 41 05 AC                A ¬
000000240   10 00 00 00 21 F7 00 0A  00 00 00 05 00 00 00 00       !÷
000000250   00 00 00 00 00 00 00 00  00 00 00 00 00 40 C5 FD                @Åý
UFS Explorer STANDARD EDITION OR PROFESSIONAL?
__________
THANK YOU
SHAHI
PostPosted: December 21st, 2010, 4:40
Use UFS Standard.
PostPosted: December 21st, 2010, 14:00
Tested UFS Standard DEMO, it did not find partitions but found files by INTELLRAW scan.
Seems it produced correct result.
Preparing to get the License for UFS Standard.
__________
THANK YOU
SHAHI
PostPosted: December 22nd, 2010, 4:10
That may mean that the file system is proprietary, but the file types are common.
PostPosted: December 31st, 2010, 1:14
UFS Explorer produces MPEG files but all are corrupted.
__________
THANK YOU
SHAHI
PostPosted: December 31st, 2010, 4:19
Have you tried to talk with the manufacturer about it ?
PostPosted: December 31st, 2010, 6:30
Even simpler : see how the user configured the box and look for the "right stuff" between the LBAs , a clue : 4 - instead of having "standard expectations" :mrgreen: Unfortunately I can't say more, Shahij, but get the hint.
Users browsing this forum: No registered users and 251 guests
