I've just found my old, broken WD400BB hard drive and thought I'd give it a try.
The hard drive spins up, gets recognised by the bios and the operating system but sadly that's all it does. When trying to read data from the device in Linux I wound up with about 40GBs of zeros (there is something else at the start of the file, I can't make out what it is, though).
File comment: Bios recognising the hard drive
Here's what happens when I plug the hard drive into an usb enclosure:
[ 2638.880953] usb 7-3: new high speed USB device using ehci_hcd and address 4
[ 2639.014555] usb 7-3: configuration #1 chosen from 1 choice
[ 2639.015152] scsi11 : SCSI emulation for USB Mass Storage devices
[ 2644.005907] scsi 11:0:0:0: Direct-Access WDC WD40 0BB 7W17 PQ: 0 ANSI: 2 CCS
[ 2644.007874] sd 11:0:0:0: [sdd] 78165360 512-byte hardware sectors (40021 MB)
[ 2644.008747] sd 11:0:0:0: [sdd] Write Protect is off
[ 2644.009870] sd 11:0:0:0: [sdd] 78165360 512-byte hardware sectors (40021 MB)
[ 2644.010617] sd 11:0:0:0: [sdd] Write Protect is off
[ 2644.010624] sdd:<6>sd 11:0:0:0: [sdd] Sense Key : No Sense [current]
[ 2644.012991] sd 11:0:0:0: [sdd] Add. Sense: No additional sense information
[ 2644.017377] unknown partition table
[ 2644.017417] sd 11:0:0:0: [sdd] Attached SCSI disk
[ 2644.017453] sd 11:0:0:0: Attached scsi generic sg4 type 0
Afterwards I hooked it up to an IDE port of another machine and gave MHDD a run. S.M.A.R.T. isn't working and MHDD generates "S" errors only. I've attached 3 pictures of the bios and MHDD recognising the hard drive. I also attached a picture of the errors shown in MHDD.
File comment: MHDD recognising the hard drive
File comment: MHDD errors
Additionally I recorded the sounds my hard drive is making when starting, trying to read something and stopping. The sounds coming from the hard drive when reading is most noticeable when reading lower sectors and gets more and more quiet when reading higher sectors.
File comment: WD400BB starting, trying to read something and stopping
wd400bb1.mp3.zip [493.33 KiB]
Downloaded 712 times
I'm new to all this hard drive repairing stuff and to this forum and just trying to provide you with as much information I can get. Can you make any useful assumptions out of this? The MHDD FAQ says, that in case MHDD reports 100% bad blocks "it is either a head crash, pcb damage or firmware issue".
