 Post subject: I have to export the data from an HP Vestra 05/20 computer.
PostPosted: December 29th, 2010, 13:23
It's a computer with Windows 3.1, and I don't have a mouse for it, only a keyboard. It has a diskette and cd opening, but I don't know if they can burn things. Also, there's no USB entrance.
Is there a way in which I can recover the data?
Thanks,
DLA
 Post subject: Re: I have to export the data from an HP Vestra 05/20 computer.
PostPosted: December 29th, 2010, 13:31
There are programs that allow file transfer on parallel/serial port, otherwise if it has a NIC (network , LAN) you can setup LAN and share the disk so you can access the disk over the LAN. Simple.
Even simpler : take the HDD apart and connect to another PC and copy what you need. Note : if disk is rather old it may not support LBA only CHS.
PostPosted: December 29th, 2010, 16:25
There is a commercial product called LapLink:
http://www.laplink.com/
Otherwise MS-DOS includes Intersvr and Interlnk commands for file transfer over a serial or parallel cable.
http://en.wikipedia.org/wiki/List_of_DO ... 6_interlnk
http://en.wikipedia.org/wiki/LapLink_cable
Users browsing this forum: Google [Bot] and 58 guests
