 Post subject: ST91000430AS --- new series with new common problem?
PostPosted: December 24th, 2010, 3:46
This is a portable 1tb drive ST91000430AS, always busy with the following Terminal:
ExecuteSpinRequest
FAIL Op=0100 Resp=0003
Send Status: COMRESET seen
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.132 msecs
F3 2>U
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 7.182 secs
R/W Status 2 R/W Error 84150180
F3 2>/1
F3 1>N1
Failed to load overlay 00000004
LED:000000CC FAddr:0026E6CF
any clue on this?
 Post subject: Re: ST91000430AS --- new series with new common problem?
PostPosted: December 24th, 2010, 6:50
New series with common problem : INVALID DIAGNOSE.
BIG clue : READ CAREFULLY THE LOG.
:mrgreen:
PostPosted: December 24th, 2010, 10:07
Looks like you have spin error. Maybe no spin at all? Maybe sticktion? Thats just speculation on my part.
PostPosted: December 24th, 2010, 17:26
Most likely it's a sticktion, agree with Mr.Alexii.
Can you hear the drive spin up ?
PostPosted: December 28th, 2010, 4:44
the drive is spinning fine.
no clicking, but a small hmmmm sound every 1 second once.
PostPosted: December 29th, 2010, 1:13
any clue reg this hmmmmm sound?
Somewhere i read about shorting pins for ES2 drives.
But, the PCB layout was different.
Is this drive ST91000430AS (2.5") belong to ES2 series?
PostPosted: December 29th, 2010, 10:29
I have no clue. Sry m8.
PostPosted: December 29th, 2010, 11:12
I have one. Dropped drive ?
PostPosted: December 29th, 2010, 16:35
damaged SA area!
The heads are slowing down the spinning (phisically) because of surface problem, and the drive can't reach the correct RPM.
I have this issue too on one drive. (partially recovered)
Janos
PostPosted: December 29th, 2010, 18:12
I thought about dropped drive. If so = pack imbalance and reading loss.
PostPosted: January 28th, 2011, 17:52
I have this drive and same condition.
Only the hum is really an internal beep.
I guess the critter ain't spinning up then.
So PBC fix is out, it will have to be a head swap - yuck!
There goes a chunk of $$$-
Anyone found that the head arms could be fixed?
PostPosted: January 28th, 2011, 18:18
Have you even looked inside yet?
PostPosted: January 29th, 2011, 13:40
When next post will have had a look.
Maybe the head arms are stuck.
Fear and loathing in North Carolina :)
PostPosted: January 29th, 2011, 14:15
OK - looks normal enough, no etching on top platter :)
Arm however is sitting on plate not in housing.
I guess if I spin it up I will see if new head is needed
or what.
PostPosted: January 29th, 2011, 15:22
Certainly Stucktion.
However, while the drive behaves better.
Allowing for /2
and Z down.
the U gets another Spin Error.
So I'll try one other thing and then order head.
Unless a clue or tip is ready made in your mind...
Users browsing this forum: No registered users and 56 guests
