 Post subject: Seagate baracuda LP ST31500541AS stuck on BSY
PostPosted: December 6th, 2010, 8:14
I have a case with a Seagate LP drive model ST31500541AS stuck on BSY
the currents look fine from the occilloscope in Atola insight so I guess it's a version of the usual firmware bug.
In the terminal i get
Rst 0x20M
LED:000000CD FAddr:00006CCB
but crtl+Ζ doesn't work to interact with the drive. Any insights?
Thanks in advance for your help.
 Post subject: Re: Seagate baracuda LP ST31500541AS stuck on BSY
PostPosted: December 30th, 2010, 5:50
ththeod, I think you need to check your PCB first.
PostPosted: December 30th, 2010, 6:37
Check if you PCB is native.
Then if it is, you can try to follow up unlock procedure, but you must short the read channel.
PostPosted: April 27th, 2011, 4:46
Sorry i forgot to update it as solved, it was fixed using the r/w channel short method using the same pcb, I just didn't find the short points at that time and it had a new pcb. Thanks for your concern!
PostPosted: April 27th, 2011, 5:11
Nice.
PostPosted: October 18th, 2011, 16:55
Hello, ththeod!
I have the same situation, can you give me more information about sing the r/w channel short method for this drive?
Many thanks!
PostPosted: October 18th, 2011, 17:34
Also the only thing I get in the terminal is
Rst 0x20M
(P) SATA Reset
PostPosted: October 19th, 2011, 4:05
If you get that on terminal the drive should go to ready no ?
PostPosted: October 19th, 2011, 6:22
No, after power on, BIOS can not recognize this drive. It is not detected by BIOS anytime. :(
Later I'll write more detailed information, how I try to get connected to the terminal of this drive.
PostPosted: October 19th, 2011, 17:35
So, crtl+Ζ works, it is needed just to press right after Rst 0x20M, before (P) SATA Reset
BIOS can not recognise HDD, and it does not continue booting, if HDD attached, it gets stuck trying to detect HDD.
Here is the pictures of PCB
File comment: PCB
File comment: PCB
PostPosted: October 20th, 2011, 3:09
And can you run any commands while it's BSY ?
PostPosted: October 20th, 2011, 4:05
Yes, no problems with executing commands. E.g. U and Z works fine.
PostPosted: October 20th, 2011, 4:41
Have you tried to regenerate translator?
PostPosted: October 20th, 2011, 5:39
No, I did not try to use m0,6,2,,,,,22
PostPosted: October 20th, 2011, 7:29
Try to clear Smart and then regenerate translator.
PostPosted: October 20th, 2011, 11:19
I know one data recovery pro in Kazan, you might want to consider taking your drive to him if data is important.
www.datarecoveryne.com
PostPosted: October 20th, 2011, 13:49
No, data is not important.
I just want to bring back HDD to working state.
PostPosted: October 20th, 2011, 14:42
No result :( The same situation after this operations.
BIOS can not continue booting, just trys to detect this drive.
Rst 0x20M
(P) SATA Reset
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 12.615 secs
F3 2>U
HighPowerMode 002F
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 9.392 secs
F3 2>/T
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = 1F5C
User Partition Format 2% complete, Zone 00, Pass 00, LBA 00009A64, ErrCode 00000080, Elapsed Time 0 mins 30 secs
User Partition Format Successful - Elapsed Time 0 mins 30 secs
Zone re-format was skipped.
F3 T>
PostPosted: November 25th, 2011, 12:35
somebody could solve the problem, because now I have the same
Rst 0x20M
PostPosted: November 25th, 2011, 16:42
Possible solutions and suggestions have been provided throughout the forum. Use the search function with relevent keywords.
If not sure what to do or it seems overwhelming, send to a pro.
Users browsing this forum: Google [Bot] and 59 guests
