 Post subject: Westerb Digital 1TB Ext HDD
PostPosted: December 28th, 2010, 23:59
My 1TB ext HDD cannot be read by windows. But I can see the icon at the bottom right corner.
I cannot format it either.
Pls help. Thanks
 Post subject: Re: Westerb Digital 1TB Ext HDD
PostPosted: December 29th, 2010, 4:14
You see the icon as the USB connection was detected, but that doesn't mean your drive is being detected as well.
Go to Manage under My Computer (right click) and check if the drive is there. If so, you might have a logical issue, and maybe can be solved with some app. If not, try to replace the USB box first of all, and after, if your data is important, go to DR company for a diagnosis.
PostPosted: December 30th, 2010, 7:56
Done that
. My computer just dont recognize it.
:oops:
PostPosted: December 30th, 2010, 8:01
So I think the drive may have some problem.
What you can do is power up the drive and listen very carefully to the sound of it and let us know what do you ear.
PostPosted: December 30th, 2010, 12:18
Take the drive out of the usb enclosure and put it in a known good one or connect the drive directly to the sata connection on your motherboard.
Hopefully it's just your old enclosure that's bad.
Bosse
http://www.rescue-it.se
PostPosted: December 31st, 2010, 6:49
I stepped upon a small prog here --- the Low level formatting tool. Tried it first on one unit but nothing happened. What I did was reformat my comp, install winXP and the prog. I didnt restart the comp but inserted that 1TB WD USB..... :P :P :P was recognized !!!
So far its still formatting. Hope everthing will come in the end fine.
WISHING EVERYONE A PROSPEROUS NEW YEAR...
Rene Fr Phils
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 276 guests
