 Post subject: Hard drive recovery
PostPosted: January 4th, 2011, 19:51
I have a Hitachi 160GB notebook HDD, it was dropped while still inside a Toshiba laptop and is no longer responding. Windows 7 doesn't recognize it on my machines, and when I plug it into my desktop directly with a SATA cable, my PC freezes and won't boot if restarted while the HDD is connected. It doesn't freeze when I connect the HDD via a SATA-USB adapter. The only program that can recognize it is HDD Regenerator, but it sees it as "0" Mb and when I try to repair the HDD, the program tells me the master boot record is damaged. I need to get some music off this hard drive.
Do you guys have any suggestions? Is the HDD gone? (I don't wan't to pay $1000+ to take the data off).
Thanks!
 Post subject: Re: Hard drive recovery
PostPosted: January 4th, 2011, 19:59
Sounds like heads and/or platter damage. It needs pro help
PostPosted: January 4th, 2011, 20:08
Thanks for the reply. The HDD makes a faint, almost clicking noise when turned on, but then eventually stops making the noise. I don't really wan't to pay so much money to get my HDD repaired though...
Would putting the HDD in a freezer for a bit help? I've read about this online, and then you may be able to temporarily access your HDD to save your files.
PostPosted: January 4th, 2011, 20:12
The drive was dropped, resulting in physical damage to either the heads or the surface or both. Being colder isn't going to change that.
PostPosted: January 8th, 2011, 19:16
See this thread, but heed the warnings:
http://forums.seagate.com/t5/FreeAgent- ... 242#M11384
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 210 guests
