 Post subject: Get data from CHK files
PostPosted: January 7th, 2011, 11:01
Hi
I have a situation where I have alot of CHK files from a flash disk that was "repaired" by windows checkdisk.
What's the proper tool to get the data out from that files?
ACELab partner
 Post subject: Re: Get data from CHK files
PostPosted: January 8th, 2011, 6:06
there's some info
http://www.raymond.cc/blog/archives/200 ... -scandisk/
data recovery Poland
PostPosted: January 8th, 2011, 13:35
Thanks laptokowiec
I had already tried those programs, and they don't do anything...
Still searching.
ACELab partner
PostPosted: January 9th, 2011, 4:35
It may help to search the drive for files with a "last accessed" date/time stamp just before the crash, and just after. That could tell you what the client was doing before the crash, and what he was redoing afterwards, in which case you may have a better idea of the file types.
PostPosted: January 10th, 2011, 7:20
If those progs don't work, you can 'watch' your files in some hexed (HxD is free) and see what type they are.
PostPosted: January 10th, 2011, 10:46
Hi laptokowiec
I used Winhex, and could find the doc's I think I needed. Still have to check with the client now.
ACELab partner
PostPosted: January 12th, 2011, 12:36
http://www.ericphelps.com/uncheck/
Might be handy :D
PostPosted: January 12th, 2011, 13:36
Might be handy :D
It didn't solved. Had to be with Winhex.
Thanks.
ACELab partner
