 Post subject: MHDD
PostPosted: January 13th, 2011, 14:26
Hi To All Members, And Special Hi For "Dmitry Postrigan"...
Here Is My Problems...
I Have Gigabyte GA-P35-DS3R (Rev 1.0) Motherboard...
My Problem Is That On Most Laptops, Toshiba, And Others I Didnt See Hard Drives In MHDD, So On My Pc With Above Motherboard Too... Only Where Worked For Me Is On Medion Laptop...
I Used To Remove HPA From Hard Drive...
I Just Want To Ask, Can You Add Better Suport For Gigabyte Motherboard In Future Versions Of Mhdd, And To Add Suport For FATX Drives...
I Used Mhdd On Medion Laptop To Clear HPA From Xbox 360 HDD, But Can You Please Make Better Suport For Gigabyte Motherboards... Because I Can't See Any Hard Drive In Mhdd...
Respectfully,
Goran Nikolic.
 Post subject: Re: MHDD
PostPosted: January 13th, 2011, 14:30
Probably your BIOS is set to AHCI mode, for MHDD to detect SATA drives the BIOS will need to be set to IDE or Legacy or ATA or whatever your particular BIOS calls it
PostPosted: January 14th, 2011, 7:54
Thanks For Reply...
When I Go To Bios, Behind Option "Integrated Periferals" Here Is What I Have...
1. SATA RAID/AHCI Mode (Disabled)
(Disabled) (Raid) (Ahci)
2. SATA Port 0-3 Native Mode (Disabled)
(Disable) (Enable)
3.Onboard Sata/Ide Device (Enable)
(Enable) (Disable)
4. Onboard Sata/Ide Ctrl Mode (Ide)
(Ide) (Ahci) (Raid/Ide)
I Tryed Some Combinations But No Luck... Can's See Any Of HDD's In MHDD 4.6
Am Only Usig Sata HDD's And CD-Rom... No Ide Devices...
Can Someone Help Me???
Users browsing this forum: Google [Bot] and 93 guests
