Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Maxtor 541DX (2B020H1) swapping PCBs
PostPosted: January 14th, 2011, 22:09
J2 is the connector for the preamp and voice coil.
I can't answer your RADIX question, though. Whatever it is, it appears to be associated with the motor controller IC.
PostPosted: January 15th, 2011, 11:01
Hi again ...
Sorry about the confusion. I have a bunch of hard disks (dead or alive) and gave the above one the wrong diagnostic :
BIOS finds it, but not Windows. It does not appear with the other peripherals.
PostPosted: January 15th, 2011, 18:30
Try running a diagnostic from a bootable CD or flash drive.
PostPosted: January 16th, 2011, 3:01
Nothing works if the drive is recognised as 'Maxtor ATHENA' instead of 'Maxtor 2B0xHx' even if you cry. Until drive is fixed.
PostPosted: January 16th, 2011, 6:05
RADIX is the Radial Index Mark (Part of servo subsystem)
Jarvis wrote:
Hello Everybody,
Hello Stripy,
I've got something you will maybe need. It seems to match your model. BUT, the problem is the following: it starts, it spins but it clicks-clicks-clicks... I'd eventually like to save it before throwing it away. Could someone tell me what I could do with it ?
Too, I wondered what are those RADIX and J2 connectors on the PCB.
Many thanks in advance.
Cheers.
http://img687.imageshack.us/i/maxtor2b020h1a.jpg/
http://img522.imageshack.us/i/maxtor2b020h1b.jpg/
Users browsing this forum: No registered users and 233 guests
