 Post subject: data corruption
PostPosted: January 17th, 2011, 20:12
:mrgreen:
hi all
I often happens that when retrieving data, they then can not read and are corrupt.
to be the problem? How can I fix?
 Post subject: Re: data corruption
PostPosted: January 17th, 2011, 20:14
There are tons of reasons for corrupted data, so you should be more specific or I'm sure no one will be able to help you.
PostPosted: January 17th, 2011, 20:19
for example after a format, try to recover the data with any software and displayed on its most corrupt.
PostPosted: January 17th, 2011, 20:29
That happens because probably a good part of the data was rewritten already.
PostPosted: January 17th, 2011, 20:50
whether the data were overwritten no chance to recover?
PostPosted: January 18th, 2011, 4:50
That's right. What is rewritten there's no chance to recover.
Might be possible to recover some small portions of data, but I don't of no use for data recovery purposes, but only in some cases for forensic jobs.
PostPosted: January 18th, 2011, 5:11
If the drive it's just formatted, you can recovery almost all info. But with an overwritten your percent of recover info will be lower an most of it corrupted.
