 Post subject: 2x WD Scorpio Blue WD3200BEVT-60ZCT1 noise?
PostPosted: January 20th, 2011, 12:18
Greetings to everyone,
I recently bought a NAS system and installed two identical WD 2,5" drives for testing purposes. I started to observe strange behaviour
when i disconnected the drives from NAS. Both drives make an strange noise randomly(seems to me random) like a restart from the motor. I can access the disk normally and backup my files,when the motor restarts it just pauses for 2 secs and then continue normally.I used CHKDSK to check the drive for errors and i even low-level format the drives. Both CHKDSK and simple format completed without the motor restart(strange noise). Using low-level format shows errors in many sectors then continues normally.The problem seems to occur when i access the disk and copy files from and to it.
I downloaded the sound files for WD disk but none seems to match my case. After reading some posts here i also tried to clean the disk contacts carefully but it didnt help much.
I could use some help here...any suggestions?
 Post subject: Re: 2x WD Scorpio Blue WD3200BEVT-60ZCT1 noise?
PostPosted: January 20th, 2011, 17:34
If you got the data off I would recommend RMAing them back to WD if they are under warranty, if not get rid of them or keep them for sentimental purposes .
I would replace them either way.
PostPosted: January 20th, 2011, 17:38
Agree with Cleanroom,
Sounds like bad sectors in multiple zones that makes the heads back to the parking area.
PostPosted: January 21st, 2011, 10:42
Thx for your replies. Seems i have to buy a new disk for my laptop.
