 Post subject: western digital 750 not showing any partition or data
PostPosted: January 20th, 2011, 12:11
today morning the hard is working xp is running suddenly system restart then it give error error Disk Read Error Occurred. Press CTR L ALT DEL to restart
i check from hard disk test tool it detect every sector as bad but not repair it
acronise don't open it hang on scanning partition only western digital data life guard show partitions
and partition find and mount find 1 partition but when i mount it it say data is write proctored plz help about it is it master password lock but atapwd 1.2 does not detect hard
 Post subject: Re: western digital 750 not showing any partition or data
PostPosted: January 20th, 2011, 17:34
Your drive isn't locked by ATA Password. It's a logical problem in the file system.
You'll need to download a recovery program like (R-Studio) or similar and clone your drive then work on the image to retrieve your data.
Good luck.
PostPosted: January 21st, 2011, 4:22
Cloning the drive is the first and best option
RAID/Server Recovery
PostPosted: January 21st, 2011, 14:57
thanks for the reply i test cloning but norten ghost open the hard partitions after 45 to 60 mins while i say ignore bad bloks and also it donot show 3 partitions
also the last partitions is encripted with truecrpt on fly encription some guide line about it
and i run some recovery software but it donot show any partition rstudio can clone damage hard drive
But the western dgital data life guard show all partion in utiltize section to copy partiion plz share your experience
The hard is in warrenty and i also purchased a 1 tera hard i want to get my data which is more then 600 gbs
PostPosted: January 21st, 2011, 15:01
You need a sector by sector clone like hdclone.
PostPosted: January 22nd, 2011, 3:13
Which city you are frorm ?
PostPosted: January 22nd, 2011, 4:31
Rwp
PostPosted: January 23rd, 2011, 9:05
why not try some data salvage software which would help you to regain lost data from the failed hard drive. i am not fully sure it would work for your case, but i have used such software services with good success and helped me to be all smiles again.
Users browsing this forum: No registered users and 53 guests
