 Post subject: WD15EARS firmware corruption recognised as 2.2Tb
PostPosted: January 23rd, 2011, 8:51
i have an addonics comtroler and 4x 1.5 Tb wd15ears drives set up as a BIG4 volume.
After a power loss one of the members is recognized as a 2.2TB so the raid won't rebuild.
I didn't find any solution to reflash the firmware to restore this drive to his normal state.
Obviously WD support wants to swap the drive and say they cannot reflash the firmware.
Please help!
AxS
 Post subject: Re: WD15EARS firmware corruption recognised as 2.2Tb
PostPosted: January 24th, 2011, 7:28
Whats your goal? Why you need reflash the firmware?
I think, your should just change corrupt drive and create new array it is much easy.
Angel Data Recovery
PostPosted: January 24th, 2011, 16:42
It's a 6Tb raid volume and obviously no backup, recovering the firmware would allow me to recover the raid , hence the data.
If you know a way to reflash it it would be appreciated.
rgds,
PostPosted: January 24th, 2011, 17:10
There is no such thing as "reflash the firmware" for hard drives
Which drive is it that failed? How much data did you have on the array?
PostPosted: January 24th, 2011, 17:17
there was 5.6Tb of data all together drive 2 failed.
i read that wd15ears are known for this issue and that rewriting SA sector with correct data could revive the drive long enough to recover the data.
True or false?
PostPosted: January 24th, 2011, 17:20
where did this 'thing' come from?
PostPosted: January 24th, 2011, 17:27
True or false?
True, in the sense that eating a pill when you are sick could make you get better.
You need to find out specifically what is wrong, have the knowledge or research to find out what you can do to address that specific problem, and then implement the solution. If you eat the wrong pill or eat too many or not enough it can kill you. Or it could be that you don't need pills at all, but brain surgery instead.
PostPosted: January 24th, 2011, 18:13
apparently a power cut is enough for the western green to corrupt the firmware...
I cannot confirm as i was away from the machine when it did append.
That i know is the drive is recognized by the bios as being a 2.2tb.
i tried to recover the data on the remaining drives with r-studio, so far not much luck ...
PostPosted: January 24th, 2011, 18:21
In this case I think the only solution is pro recovery
PostPosted: January 24th, 2011, 18:25
5.8 Tb is kinda out of budget....
PostPosted: January 24th, 2011, 18:49
Power cut as the cause ? No , simple crap drive. Anyway pro intervention is needed , but in my opinion I have the feeling the quote would not be that high, if only no physical intervention like cleanroom work is needed.
Users browsing this forum: Google [Bot] and 225 guests
