 Post subject: seagate drive Baracuna 500 GB, & 1 TB detect 0 byte in BIOS
PostPosted: January 29th, 2011, 5:33
I have some seagate drive Baracuna with spaces 500 GB, & 1 TB...There drives detect 0 byte in BIOS computer ...How to fix, repair & recovery data to the drive??? please give me solution??? Leo Jakarta.
 Post subject: Re: seagate drive Baracuna 500 GB, & 1 TB detect 0 byte in BIOS
PostPosted: January 29th, 2011, 5:49
Hi, this is a good feature:
http://forum.hddguru.com/search.php
Bosse
http://www.rescue-it.se
PostPosted: January 29th, 2011, 6:49
harddisk-500gb-the-bios-known-zero-bytes-t18146.html
Check with Seagate to see if you are entitled to free data recovery (for 7200.11 drives).
Alternatively, see the following thread for an easy DIY fix:
http://forums.seagate.com/stx/board/mes ... 467#M18467
See the following bulletin for an explanation of the BSY bug.
Urgent Field Update. Topic: Drive Hang after Power Cycle:
http://www.expreview.com/img/topic/seag ... Update.pdf
PostPosted: January 29th, 2011, 8:22
I do not recommend DIY here if data is important, contact a member here in this forum called "prodata"
member155.html
PostPosted: January 29th, 2011, 23:20
member155.html
Agree what you think is a bug is not a bug and you do need some help on this one. Note if you try to fix the bug of 0 LBA or even the Busy one and this is not what is wrong with this HDD then kiss your data good bye. Contact prodata and go from there he can diagnose this one for you and you can get back your data when it is done. Good luck I would not really follow advice of DIY if you kind of think your data is important to you.
Iorana Haraharaini
PostPosted: January 30th, 2011, 0:10
Contact Seagate. They are still offering free data recovery for drives affected by the BSY bug. Otherwise a DIY fix will cost you a few dollars and a little time.
PostPosted: January 30th, 2011, 0:12
seagate-drives-led-000000cc-bug-aka-busy-bug-faq-t17831.html
PostPosted: January 30th, 2011, 18:07
DIY is easy if you know your basic computer skills. Here, this should help greatly! -->
http://www.msfn.org/board/topic/128807- ... 0011-hdds/
Users browsing this forum: No registered users and 72 guests
