 Post subject: Usb Drive Head Snapped Off
PostPosted: February 2nd, 2011, 13:49
Greetings Everyone
I have a USB stick with a broken head, it seems the padding is gone. Is there any way to replace the padding or to repair this usb stick?
Any help is much appreciated.
Thank You
 Post subject: Re: Usb Drive Head Snapped Off
PostPosted: February 2nd, 2011, 14:28
I think someone got a little carried away with the heat gun
PostPosted: February 2nd, 2011, 16:40
Did you use a blow torch to solder?
PostPosted: February 2nd, 2011, 23:49
no my friend tried to repair it, he used a butane solder
is this usb stick still repairable?
PostPosted: February 3rd, 2011, 0:40
I think your only hope is if someone (not DIY) could read the nand chip(s) on the other side. Post a pic of the other side.
PostPosted: February 3rd, 2011, 9:11
do you need take back data from it?
data recovery service[/b]
PostPosted: February 7th, 2011, 9:21
that been done with a heat gun as you can see on the main ic chip
and for sure not a butane solder gun
easy way is just buy another usb head there are some on ebay
solder it back on and your good to go
PostPosted: February 7th, 2011, 11:02
or just pop over the border to Schenzen and buy from the market ;o)
Users browsing this forum: No registered users and 21 guests
