 Post subject: Western Digital Locked - Can't find password on dump files
PostPosted: February 3rd, 2011, 21:33
Hi everyone, I've got this hdd locked...
I've dumped the security info from the hdd registers but now I'm habing troubles getting the password
I'm looking someone's to help find the password on the bin files.
Thanks...
bin_files.rar [735 Bytes]
Downloaded 367 times
 Post subject: Re: Western Digital Locked - Can't find password on dump files
PostPosted: February 4th, 2011, 5:07
user pass:
1F 00 16 00 31 00 14 00 17 00 17 00 02 00 08 and so on.
Master is
8A 00 3A 00 ........
DataRecovery.bg
PostPosted: February 4th, 2011, 8:19
Thank you so much I will try it later...
Anyway, how do you know were start and finish the passwords?
I realy am curious about it :)
PostPosted: February 4th, 2011, 10:09
Ok, so i've tryed but no results!
I've converted the hex to dec values and entered in mhdd with the dispwd command and 0 (user) option the values:
310000220000490000200000230000230000230000020000080
which correspond to:
310 000 220 000 490 000 200 000 230 000 230 000 002 000 008
I've also understand that the user password begins after the header: 01 07 00
What am I doing wrong?
How should I input the values on mhdd? With spaces in between the 3 number group?
I heard about a trick with alt key how it's supposed to work?
HELP :)
PostPosted: February 4th, 2011, 10:32
In mhdd, you have to enter the password as ascii characters. You have to convert hex value to dec values on a byte basis so 0x1f is 31 and then press alt, type 31 on the keypad and then release the alt-key.Repeat that for every byte of the password. Unfortunately this won't work with dos programs because the byte 00 (and others) cannot be entered this way.
PostPosted: February 4th, 2011, 10:40
I've tryed the way you told me but no luck.
Every time I press alt I can't input values, why is that happen?
PostPosted: February 4th, 2011, 10:49
Is there any other way of doing it?
I really need this data, I can't afford to pay a professional service.
Help me out guys!
PostPosted: February 4th, 2011, 11:07
very cheap solution - http://www.hddunlock.com/purchase/
PostPosted: February 4th, 2011, 11:15
Doomer thank you but that's not the kind of solution I'm looking for...
It must be a way, there's always a way right?
PostPosted: February 4th, 2011, 11:35
I think that Doomer's suggestion is the cheapest way. If your data isn't worth that little, then move on.
PostPosted: February 4th, 2011, 12:05
Thanks a lot for all your help!
PostPosted: February 18th, 2011, 8:18
I have recuperated a western digital HDD from a televisionnetbox : WD3200AVJS and want to use it in a PC.
This HDD is protected by paswoord. You find the result of MHDD in the upper part of the file in attach.
There is no "01 07 00" but well "01 0f 00". Is the first user PW the 32 bold bytes after it ? Is the second one the next 32 underlined bytes array. Where is the master PW ? Does it end just before the 00 in front of the XXXX ? But where does it start ?
The second part of the file in attach is a image from another forum of hddguru. It has been said that the marked bytes are the master PW. You can find the same array of bytes in the upper part, but the similar array starts earlier as you can see.
With kind regards
Fichier22Comparaison.pdf [63.01 KiB]
Downloaded 455 times
Users browsing this forum: Bing [Bot] and 106 guests
