 Post subject: Error only discovered by the writing process?
PostPosted: February 4th, 2011, 18:07
I've seen this error on a website about hard drives (in French). What do you call this sort of error?
Translation:
The error will not be treated as a bad block. Error only discovered during the writing process
and not the reading process. Can only be detected by professional software.
 Post subject: Re: Error only discovered by the writing process?
PostPosted: February 4th, 2011, 19:40
I don't really have a name for it i guess; but it could be caused by several things:
Faulty RW channel
Faulty Preamp
Faulty write element of heads
Failing media
I am sure there is more, but there are still a lot of possible issues that can cause a HDD to read, but not write properly.
Regards,
PostPosted: February 6th, 2011, 0:13
FYI, some drives support the ATA Write-Read-Verify feature set, but with a performance penalty.
Users browsing this forum: No registered users and 43 guests
