 Post subject: Unlock USB drive (WD My Book Essential Edition 2)
PostPosted: February 5th, 2011, 20:36
Hey,
I have a WD My Book Essential Edition 2 WD5000H1U-00 (http://support.wdc.com/product/install.asp?groupid=110&lang=en) and wanted to run an ATA security erase. For that purpose I started hdparm 9.37:
hdparm --user-master u --security-set-pass asdf /dev/sdb
hdparm --user-master u --security-erase-enhanced asdf /dev/sdb
The first command worked but the second one to start the security erase showed an error message. So I tried
hdparm --user-master u --security-erase asdf /dev/sdb
but this doesn't work either. So I gave up and wanted to unlock the drive:
hdparm --user-master u --security-unlock asdf /dev/sdb
The output was:
security_password="asdf"
/dev/sdb:
Issuing SECURITY_UNLOCK command, password="asdf", user=user
The running kernel lacks CONFIG_IDE_TASK_IOCTL support for this device.
SECURITY_UNLOCK: Invalid argument
Do you know how to unlock the drive? I think the problem is that the USB controller does not pass the unlock and security erase commands to the hard drive. I don't want to dismantle the hard drive to connect it directly because I don't want to damage the enclosure.
I've attached the output of
hdparm -I /dev/sdb
File comment: Output of hdparm -I /dev/sdb
hdparm.txt [2.84 KiB]
Downloaded 565 times
 Post subject: Re: Unlock USB drive (WD My Book Essential Edition 2)
PostPosted: February 6th, 2011, 12:56
Hey,
I disassembled the HDD and connected it directly to the SATA port. Unlock fails in hdparm and MHDD. How can I reset the password? There is no important data on the drive.
Users browsing this forum: Google [Bot], WebClaw and 42 guests
