Forum rules
 Post subject: Adding hardware write protect switch
PostPosted: February 14th, 2011, 15:51
Hi All,
I have seen lots of modding and hardware hacking on this forum, so I hope this is the right place to ask my question.
I will appreciate, if somebody suggests a way of adding a hardware write-protect switch to a SATA HDD, or SATA Enclosure.
HDD - Hitachi HTS545032B9A300
Enclosure - Toshiba Transcend StoreJet 25 SATA (Chipset: JMicron JM20329)
Thanks in advance
 Post subject: Re: Adding hardware write protect switch
PostPosted: February 14th, 2011, 20:20
There is no easy way to write protect your drive.
You should modify the FW, or use linux.
Under Linux you can write-protect any HDD as you want with this:
blockdev --setro /dev/sd....
If you want write protected usb storage, (without modding) you should look around for older pendrives wich can be write protected.
Janos
PostPosted: February 15th, 2011, 3:40
Actually hardware "Write-Blocker" is used mainly for forensic imaging.
You can find it here:
http://www.wiebetech.com/products/USB-WriteBlocker.php
http://www.tableau.com/index.php?pageid=products&category=forensic_bridges
Good luck!
PostPosted: February 15th, 2011, 13:54
Thank you N.C. and mdarwish for the prompt response.
Does "use Linux" mean using Linux on the host computer, or I could run some type of Linux on the USB HDD itself, so it can protect the transfer and prevent from infection?
Regarding the USB Flash Drives, I found an effective software way to protect it; just filling the empty space to the last byte with a dummy file, or files in case the space is more than 2 GB.
I am still open to any suggestions,
Kind regards
PostPosted: February 15th, 2011, 15:21
Kind regards
The filling is not good enough because this will not protect from boot sector viruses or under NTFS, from viruses wich can fit in <1KB.
Additionally there is more spaces are left on the filesystem's spaces wich is reserved from file-usage, but viruses can use these...
btw i have an idea:
I have seen some utility wich can configure the pendrive's controller, and you can "partition" the space and build up a CD-rom image on it. ;)
This must be useful for you.... ;)
Janos
PostPosted: February 15th, 2011, 15:25
http://situsnya.wordpress.com/2009/01/1 ... indows-xp/
PostPosted: February 16th, 2011, 14:06
Thank you all for the suggestions.
Users browsing this forum: No registered users and 28 guests
